Yellow/Blue = 4600
Silver/Black = 5100
Both a big upgrade over the stock shocks. Go with the 4600 if you want to keep stock height or are needing maximum control for towing or want to run a leveling spacer. Go with the 5100 if you want to level the truck without a spacer or if you like to go offroad.
Running stock 16 1500 crew z71. I have a Leer cap on back which probably adds 300 lbs and already squats the back a bit over stock. Would there be a noticeable benefit to just do the rears with 4600 or 5100 simply because I can do it myself? I don't go off road that much and would like a smooth ride on the highway.
Do the 5100s that are adjustable, do they actually raise the front all by themselves? Or is it just to account for a seperate lift or spacer? If I wanted to raise the front say an inch to level it out a bit would you need to replace other suspension parts and get an alignment, or is all you need the are the 5100s?
Thanks
5100 front shocks have a circlip that raises a perch that the coil spring rests on. Raising the circlip raises the front of the vehicle. I have mine set at the third setting which leaves me about 1" of rake. I also have a topper (ARE) on mine.
You will need an alignment if you raise the vehicle.
Thanks for the info. How was the ride quality after the 5100s with the cap on the back? I noticed adding the cap alone really tamed the rear bounce from how it drove with an empty bed.
You should only see improvements in the way it handles and carries the weight of the cap. We recommend you go with the 5100s. The front shocks have an adjustable spring seat to level out the front. All you need is the shock set, they come with everything required to install and level the vehicle, no additional parts needed :)
Well to be honest I'm not too thrilled with the rear ride. It's a little jarring. I had a Tacoma with Bilstein 5160 rear reservoir shocks that rode much nicer. I may put the stockers back on.
Edited by Threerun
Could I clear a 285/50/22 Nitto G2 with Bilstein 5100? That is a 33.2" tire at 11.2" width. Or even without any mod? The stock 285/45/22 is 32.1" and also 11.2" width.
275/60/20 fit without any modifications--that's a 33" at 10.8" width.
It will depend on the offset & backspace of your wheel, that tire is wide and may rub the upper control arm. Height wise it should be no problem to fit with the BIlstein opn the top setting.
So, according to the pdf, are we really only looking at 1.8 of front lift on the Sierra/Silverado with the 6112's?
Anyone know if these numbers are confirmed?
Thanks.
http://cart.bilsteinus.com/pdfs/off-road.pdf
Not confirmed yet - check out this thread for the most recent 6112 info: http://www.gm-trucks.com/forums/topic/190363-bilstein-6112-coilovers-5160-rear-shock-interest-thread-50-sets-co/?hl=6112
I have been thinking of putting lowering shackles on mine to try and even the rake. Would either of these shocks be good for this. I would like to take some of the bite out of the Z60 harshness. Sprinkle GSM in front would really probably help. I am 2wd and extended cab.
What the heck does Sprinkle GSM in front would really probably help. My phone must have auto corrected that. I was thinking springs in front would probably really help.
Would my truck benefit more from 4600 or 5100's? I am wanting some of the Z60 harshness taken away. Expansion joints on the interstate and bridges currently suck.
LOL! If you are lowering the truck, go with the 4600 as they are shorter than the 5100s.
Thanks man for the reply. At this time I only want to lower the rear with shackles. No plans for the front.
I have a 2017 CCSB 4X4 with the 6.2L (L86) and Max Trailering Pkg. I tow a 34' Airstream trailer (9,100 pounds and 1,100 tongue weight. I want to maintain the factory ride height, but I'd like a more controlled ride, especially towing. I want the damping to be more controlled...not harsh.
Would the 4600 series Bilsteins be an improvement over the factory shocks?
Thanks,
Steve
Are their any Bilstein's for lifted trucks? I have a 7" lift on mine but I'm not too impressed with the shocks that came with it.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 1,234 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
