2014+ Best Air Intake
I dropped it on the garage floor when i was prepping to drive to the SEMA show. It left a pile of dirt on the floor
Wow, those conditions must be pretty bad! Nothing like my area! Ya not sure if I would wait 100,000 miles either haha
  • 4 weeks later...
  • Replies 68
I'm running the AFE Momentum GT, makes a nice growl and I did notice a little bit of better throttle response.
  • 9 months later...
does anyone have the Vararam system in there truck?
  • 2 months later...
Has anyone had experience with cold air inductions or S&B? I like the looks and features of both of them. But the S&B is $100 cheaper.
  • 3 months later...
  • 2 months later...
Anyone comment on sound on air raid MIT under normal acceleration / crusing speed RPM?
Maybe I'm getting older but one thing I love about my 2kxx over my gmt900 is how quiet the cabin is. Like to slap in an MIT and a decent stock replacement filter (K&N or maybe explore dry filters) to get that small gain in efficiency but if it's going to be loud I may steer clear. I know on my 2011 and my 2004 the K&N intake made the fine much growlier but alas not what I'm going for any more .
Airaid MIT is much quieter on my '17 than it was on '11, and I reused the same tube.
K&N high capacity filter in the stock box.
Only make some additional noise during heavy throttle
Now that i have the exhaust installed they make a beautiful sounding pair
I put the K&N Blackhawk on my 2016 5.3. Noticeable chance in sound (in a good way). Hard to tell a performance difference, but as most people have pointed out, it's nominal, likely a 10HP gain. All said and done I was $360 bucks with tax/shipping.
Cold Air Inductions. Have it on my Camaro, luv it
2nd on the Cold Air induction system. I just installed one and I like the sound combined with my GM Borla catback touring exhaust. The clear top and near chrome tube look awesome. This system is quality built and makes some pretty music on a 6.2 If you have plenty of disposable income well chit go buy what you like LOL. Never going to justify the expense of a CAI by saying that it produced HP / Torgue and MPG increases that is all BS the payoff would be like 100 years LMFAO
I did the MIT w/Dry Fliter on my 16 Denali. There is a slight increase in sound but only noticeable on acceleration while in the truck. I also replaced the stock muffler with a Borla and with the 2 combined I have experienced about 1-2 miles more per gallon.
That being said, I only spent around $275 for both the MIT and Muffler installed. I am happy with the results and did not drop a ton of money.
MIT is best bang for the buck IMO
Agreed. I have the MIT and have been quite pleased.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
