2015 Remote Windows function
I think the vehicle manufactures have finally caught up/on with the computer makers and phone makers. The cool feature you want or need will always be in the next version/year even though they could put it in the current year. I would certainly have liked the 'all up' option. I regularly forget to roll up/close all the windows before exiting the truck. Having that as an option on the FOB would be nice!
  • 5 months later...
  • Replies 56
Hmmm...interesting. Subscribed! I'll wait to see if that little OBDII device works for our trucks...
Wow, thanks guys! Just went out and programmed my windows and mirrors! Also, what about the heated seats on auto start? Does it turn them on all the time or does it somehow sense if its cold out side? I activated mine since we're coming out of summer now, but not sure I want a hot butt every time I auto start the truck.
My wife just got a new Ford Fusion that will roll down all windows with unlock and roll all windows up with the lock button. It will even close the sunroof if open at the time you command windows up. Your move GM.....
GM will add windows up (front only) in 2017 then all windows up in 2019, rear slider '21, etc etc. It's this kind of shit that keeps our dumbasses buying new trucks. This damn push button start is going to be a record year for GM. Lol
Sent from Off Driller Side
Double post... Fat thumbs and a little phone !
Received the OBDII plug in yesterday. Works perfectly on the SS and SIerra.
auto heat activation is temp dependant.
(sorry, don't recall the temp at which it engages)
  • 7 months later...
Too bad it's not listed as compatible with the K2's. That would be sweet!
Correct. You have to have the function turned on though. I thought my Sierra wasn't equipped with the feature when I first got it, but it just wasn't turned on from the factory.
Well, I'll be damned. I just figured mine wasn't equipped with this feature. But all I had to do was turn it on.
:ughdance::idiot::thumbs::cheers:
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 850 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
