5.3 engine rebuild or buy crate
Hi everyone, new to the forum. So I was told by the dealer that I have a pitted camshaft and lifters. They wanted $7000 for a reman engine. Obviously not going to pay that. My question is, should I have someone rebuild my engine and upgrade the camshaft,lifters, springs,etc or buy a crate engine. I don't have any engine building experience so I would have to find someone reputable in my area to do the work. Looking for any input on which way would give me the best results for the least amount of money.Thanks
  • Replies 45
That is one of the options Ive been looking at. Do you think having my engine rebuilt with a better cam would be cheaper?
Drop in a junkyard 6.0. the LQ4 will give you a bump in power over the 5.3, and they are a dime a dozen with decent miles
Is the truck a DD or for seldom use? Share your needs/wants and long term plans.
That would definitely help. I don't know about the US but in Canada if you buy a crate engine from GM you get a full factory warranty with it. Again long term plans like how long you plan to keep the truck would definitely help too.
Bought my 5.3 from the local salvage yard for $900. 45k miles on it.
Included everything but the accessories, like A/C, Alt, Power Steering, etc.
Pull one out, pop the other in...
I've also been looking at ATK Engines, lately. They're remanufactured and sold through your local Advance Auto Parts. Come with a 3 year warranty.
5.3 for $1998 or 6.0 for $2197
I'm curious - why would the dealer be digging around in the cam train in the first place? ie. what symptoms led to that? How many miles? Service history?
Pitted cam & lifters aren't a reason to replace them in my experience, unless they were starting to wear badly. Even so, you don't replace the whole engine because of that.
7g's is waaaay too much for an engine that is one of the most common ever built. Out the door pricing including labour shouldn't be more than 4-5gs tops. Total labour shoudn't be more than about 15 hrs or so.
Buying a used engine and going to town on maintenance is the best option imo, short of a brand new one that will be $$$$.
This is my daily driver, Its an 05 with 195,000 miles on it. No major mechanical fixes to this point. I brought it to the dealer cause after about 10-15 minutes of driving, A knocking sound would start and would would be fast or slow depending on the rpm's. Usually when i get to a stop light and wait, the knocking would disappear.It started to get more frequent so I brought it to the dealer. They said it was the cam and lifters bought wanted to replace the engine. They wanted $7000 for a reman engine or $10,000 for a new engine. I assume they figured it was the cam by the sound and maybe previous experience with the problem. Pretty sure they didn't take anything apart cause they had it for less than a day and am still able to drive it. If i was going to rebuild it, i was looking into upgrading the cam for a little more power. Im hesitant to have a shop rebuild my engine that I don't know personally. That and do I rebuild an engine for 3000 or by a gm crate for around the same price.
GM replacement reman engine runs $3832 for a 5.3 for a 2005 Sierra. 3 year 100k mile warranty on them too. Sounds like they are hitting you big on labor and maybe some part $$ markup.
    Charly
    Charly
  • Who's Online   5 Members, 0 Anonymous, 3,374 Guests (See full list)
    • Trying to replace the temperature control, blend door actuator in my 2005 GMC SIERRA 1500, but can NOT get to it by just removing the under panel on passengers side. It seems like I will need to remove the side panel of the center console, or the entire center console just to get to it- can anyone offer instructions, pictures, videos… step by step so I can get this done!??!! It’s TOO HOT to be without AC!
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
