be aware: cupholder design flaw
d3m0n
Here is what happens when you spill any liquid into your cup holders...
EDIT: Click on each picture for a description.
I hope you did this demo on a rental!
  • Replies 49
Of course! The A/C is broken on my truck again and the parts are on back order so I've got a rental for the next few days. I couldn't believe that the slots in the cup holder were not sealed and needed to figure it out for myself. It's obvious that they are not sealed and I'm glad the op brought this to our attention.
lmfao thanks for the experiment
i just wish i discovered it a different way LOL
I noticed this as well. I always keep napkins in the door for just this reason. I stuff a couple in the cup holder and sit my drink on top. It helps soak up condensation and minor spills. It is pretty unfortunate we have to resort to this.
Ya, I put coffee in my cup holder every morning and would be pissed if it spilled and drained into the center console like what happened to you. Best of luck getting it cleaned and thanks for posting about this.
So, knowing that these cup holders leak - how many are going to be proactive and are planning to use silicon rubber, or other method, to plug the leak holes. Or, how many are just going to leave things as is and hope for zero spills? I'm leaning to plug the holes - just not sure what method I will use. I seem to recall a cloth-like water proof material that comes in black and is super sticky - could cut a short piece for each hole, fold a crease in the piece and use some needle nose pliers to push it over each hole. Or do it the right way and take the cup holder apart as detailed above and do a fix.
It's a cup HOLDER not a cup. It's to hold the CUP not it's contents. The CUP holds the liquid, the HOLDER holds the cup. Simple.
I would like to fix it. The slots in the bottom are located where the rubber on the sides flexes to hold various cup sizes. I'm afraid to use silicone because it will bond the side to the bottom and the side will not flex as well for larger cups. I'd like to pop the cup holder out and remedy the back side but am unsure how to remove the cup holder.
The rubber part of the 3 cup holder can come out. Start at the back where the lid covers it and pull up. There is a tab at the center of that and there is one on each side by the intentions between the cup and lid. I pulled mine up and cut the tabs off. I can now take the rubber part in and out like the previous year models to clean it. I found the pictures where I posted this before. The red circles are where the tabs that hold it down are. Just pull it up and cut those off.
Now that you have it out, does it look like you can seal it from the back side? Also, how did it fit back in?
  • 3 weeks later...
I just did mine. 2015 1500 Silverado. Just siliconed it from the underside. You can kinda see a little bead of silicone from the inside but not noticeable as I used black. Anyways no leaks. I left the tabs on and just pushed everything back. I can clean it now with just a rag and water. I don't really care too much about the different sizes of cups that might tear the silicone. I will just be carefull about that but not about spilling.
Jim
nothing gets by you, huh? lol
Not much. I have absolutely no trouble with reading comprehension.
Thank you very much for your astute observation, Jimmy.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
