Here's my 2015 double cab ltz with a RC 2.5" leveling kit with rear blocks. Makes a ton of difference in the looks department I think. My 275/60R20 duratracs with fuel maverick 20x9 +01 offset are on the way! 45075bf321f98995ea59a2e562b32cec.jpg
Edited by 15ltzandy
Love this information. Z71 with 2" RC Level. Was wondering if I needed to adjust headlights, and this thread answered it for me. Thanks!
Sent from Tapatalk App - Samsung S6
I finally got my Ranchos where I want them. 3 in front and 5 in the rear. I had put the front at 0 and it was like OEM ranchos. I jumped up to 3 and it rides great.
Its true Z71 has a higher rear, I was going to do 2.5 in the front and 1 in the back, however due to the z71 I only had to do the front
Where did you come up with that information?
The 4x4 pickups with the Z71 suspension sit at the same height as any other GM 4x4 truck that I have ever seen. The suspension differences between Z71, Z85, Z83, NHT ect. are mainly the stiffness of the OEM shocks. Shock length are all the same, but the shocks don't adjust ride height anyway.
All of the pickups also come with the same size rear block on top of the rear axel. The leaf springs are also the same measurements from center pin to eye with the same arch no matter the suspension package.
If any of the trucks actually were going to sit higher in the rear, common sense says it would be the options like the NHT/max tow that are rated for extra weight. Even if there would be more leafs in the pack to make it stiffer and give a higher spring rate to handle a heavier load, the truck still isn't lifted with the identical spring measurements.
The arch and measurements from center pin to eye are the same on the OEM leaf packs.
I am going to have to get some measurements next time a 14-15 Silverado/Sierra comes into the shop. The new trucks may be a little different but I doubt it. It would be very noticeable if one were higher than the other. Only difference I have seen are between 1500 & 2500.
Sent from my crappy iPhone 6
using Tapatalk
  • 4 months later...
Top is leveled with RC 2.5"with toyo MTs, bottom is stock.
If you take care of your vehicle, you will be fine. Who cares if you need to replace ball joints in 100k miles, that's part if maintenance
Sent from my SM-G900V using Tapatalk
That's probably what I'm about to do. Don't you have to swap rear blocks to get this leveled. I'll be working with a 2015 All Terrain and wanted about a 1/2"-3/4" rake?
Thanks
Ok I am really thinking about doing this and running 275/65/20 with the stock 2014 Denali rims. I know the tires are a 34 inch and a load range E which I was wanting to stay with a P metric tire just due to the weight and ride!
What are we getting with Gas mileage with the 275/65/20 E rated tires and a 2.5 lift kit or even the 3 inch Motofab kit ? I am going to stay with an AT tire and haven't decided which one yet either!
Either
Toyo Open Country AT2
Nitto Terra Grapler
BFG AT2
Yokohama ATS
Rancho Quick Lift if your budget allows......
What about Beilstein 5100. is that better them Rancho quick lift. or not.
I have a 3.5" level and I'm running a 35x12.5x20 destination m/t on a stock yukon rim
Sent from my SM-N910V using Tapatalk
Who makes a 3.5" leveling kit? Are your angles alright?
  • 7 months later...
You have probably answered this a thousand times so forgive me, but did you install the entire kit front a read? This is how I want my rig to look!!! Thanks!
rc 2.5 toyo 33x12.5x20 love it
Looks awesome!! Did you install the entire kit front and rear?
those pics are with just the front installed...i did install the 1" taller blocks on the rear a few days later...
it looked a little nose high in person...plus i tow a camper pretty often...
Before / Stock
RC 2.5 Just the front with 275/60/20 ko2 6964ef42fe843c2e99d207b18bd60f2b.jpg
The hole kit front and rear
We have the same truck. I really like the looks of yours now. What tires do you have and are you happy with them? Do you have a photo showing your truck from the front with the air deflector removed?
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 698 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
