Stuck in V-8 mode?
Engine braking was not on. I have been driving those roads all the time and it has dropped to V-4 all the other times.
Engine braking isn't a feature, it's a characteristic of all car engines so it's essentially always "on." I meant it as though maybe there is logic in software that trys to regulate speed increases (before grade brake activates.)
Yes, engines will naturally slow a vehicle down when you take your foot off of the accelerator, working essentially like a brake. Many of these trucks have Grade Braking in them, though, where the truck adjusts the gear (and the engine speed) to increase the -amount- of braking that the engine provides. This feature, I believe, is what was actually being discussed.
Ember nailed it. Sure saves on the brakes when you are towing. Very cool feature.
While I'm all for saving the brakes at that exact moment in time so that they aren't overheated if I really need them (like towing or hauling heavy, downhill, and steep), brakes are maintenance items. "Over" heating the transmission fluid (making hotter than it needs to be, not necessarily overheating it), overworking the driveline, and running the engine at higher RPMs and wasting gas are what that features "costs" you. I do like having it there as it helps keep the vehicle traveling at a reasonably constant speed and keeping me from having to keep correcting it. But, it comes at a cost - one that most of us really don't think about.
Will leaving all 8 firing increase engine breaking? I would think so, but don't know. Perhaps the truck leaves all 8 on to try to satisfy some software logic about engine braking.
Yes-- sort of. Technically the cylinders aren't firing but they are pumping air against a resriction. The effectiveness of engine braking is directly related to the displacement of the engine--V4 mode cuts the displacement in half. This is exactly why GM goes through the trouble of collapsing lifters and sealing off four cylinders in V4 mode--to prevent them from pumping air. You could get the engine to run on four cylinders by simply shutting off four injectors, but if those cylinders are still pumping air they are in effect "engine braking" when you're trying to push the vehicle forward with the other four cylinders--not exactly good for efficiency.
1) It doesn't cost any gas. The injectors are shut off. Your aren't using any gas at all.
2) It puts very little heat into the transmission--dramatically less that going up the hill does. These trucks keep the converter locked so the transmission is running very efficiently when grade braking. The transmission on these trucks while towing will cool down fairly quickly while going down hill if they had heated up noticeably going up whether they are engine braking or not.
3) While the engine does run at higher RPM, it is burning no gas so cylinder pressures are low and the engine cannot produce anywhere near as much negative torque as the positive torque it produced to get up the hill, so again, relatively speaking it's not a worry. If it was cheaper in the long run to not use the engine and simply replace the brakes more often, that's what commercial trucks would be doing.
if the engine is firing, it's using fuel. Period. There isn't a motor on the planet that burns "zero fuel" because the vehicle is coasting downhill. This also negates your argument in point three.
The engine is running, it's spinning, just not "firing." You might want to google DFCO (Deceleration Fuel Cut Off) and do some reading. I have a data log of me towing down a mountain pass where my injectors basically didn't fire at all for about 5 minutes. And my transmission cooled down by 20 degrees during that time. 14,200 GCW and I didn't have to touch the brake at all the whole way down. These new trucks rock....
I did think the same things you did years ago on the subject and there may have been some truth to them at some point as engines, clutches, transmissions, etc weren't nearly as durable back then, and computer controls not as sophisticated, but times have changed. The data speaks for itself.
Go to "instant fuel economy" on your DIC and you can actually see when the fuel shut off happens.
And you can actually feel it as well.
so long
j-ten-ner
With electronic fuel injection, it is possible for there to be 'zero' fuel injected.
I agree here. I have watched my fuel flow numbers when coasting. It drops to 0 GPM
    • I'm tangentially aware of what Harley used to be, back in my riding days, although I was into Italian sport bikes. Ducati seems to have gone the other way; still very expensive, but they've made a large subset of their bikes a lot more reliable and accessible, and they've diversified their lineup to include other riding sports too. IMO, a good example of where greed and growth might have also been beneficial to the consumer.   Although GM is charging a relative premium for its most popular pickups, I find that there are some excellent value propositions in its lineup as well.   The Colorado still strikes me as the most attractive midsize on the market, and also the most reasonably priced given capability and features. There's a part of me that wishes I would have bought one instead of my Silverado.   The Equinox ...I must be getting old. The ICE equinox is a great design IMO. Probably because it reminds me visually of an actual SUV aka an S Blazer. Underneath it's nothing even remotely close, but it LOOKS good. It's got all the modern features plus some at a very reasonable price. If I had to run out and buy myself a daily commuter to do everything except tow, an Equinox would be on my list.   It does bug me that mid-tier 1500's reach into the 50-60k range, and Tahoes and Burbs are even more expensive. Less than 10 years ago, dealers were sitting on rows of Tahoe LS and LT's for low 40's. You could even still find Tahoes with a front bench, still!
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
