Leveling kit advice please
Bilsteins are on national back order right now. If you really want to upgrade shocks, go fox shocks.
Agreed!!!!! Never was impressed with Bilstein
  • Replies 56
Yup! better than stock, stiffer than stock, more controlled than stock, but by no means are they amazing. Same with rancho quicklifts. You get what you pay for. When you can buy 5100's for cheaper than the dealer sells the stock shocks for it really goes to show you what you're getting.
The best setup will be a coil over setup. I think so many people want 5100's cause it sounds cool.gif and expensive to have "Bilstein" shocks.
http://www.socalsupertrucks.com/fox-2-0-performance-series-coil-over-ifp-shock-chevy-gmc.aspx#.VbFNcp_D_qD
What I will be going with here shortly. Coil over on the fronts
Sent from my SM-G900V using Tapatalk
I'm torn between something like that or the new 6112's. I really want whatevers going to ride nice and soft. The trd pro tacomas have a setup similar to 6112's and they're pretty bad ass. How many stock trucks are jumpable?
But no release for our trucks until late this year or early next year
Forgive my ignorance, but these will be much better than the bilsteins correct? How will it affect ride quality for someone like me who is on pavement 95% of the time? The part says its for the aluminum control arms; how am I to determine if mine has the steel or the aluminum? Do they come preloaded for 2" of lift?
Thanks for your help
Josh
Josh
Better than Bilstein 5100's..... Yes
Better than Bilstein 6112..... Debatable
I say coil over shocks are the way to go vs bilstein 5100 adjustable shocks.
Coil over shocks will absorb any bump better than just a piston style shock. Coil overs have piston and springs.
If you haven't lifted or leveled your truck, you wouldn't understand the difference in ride. Where the difference is very little, the stock shocks are junk.
Also, having shocks that lift your truck will keep a better angle on ball joints vs a level kit. Preventing premature wear on parts. ( debatable)
And if you have a aluminum control arm they will be silver, steel ones are black
Thank you very much.
I have leveled 2 of my previous trucks (2" RC on a 2008 silverado, and Bilsteins on a 2014 Ram) but so far haven't touched this one. I agree that the stock Ranchos aren't great. I was just worried that I'd be "overdoing" it by going to an expensive Fox Coil Over considering I almost never leave the pavement.
I'm very grateful for everyone that has chimed in on this thread and offered advice to me; it's truly been helpful. I have decided that I'll go with those Fox Coil Overs for the front to increase the height by 2", and some Fox's in the rear as well.
Thanks again everyone
Josh
http://www.socalsupertrucks.com/fox-2-0-performance-series-coil-over-ifp-shock-chevy-gmc.aspx#.VbGMzp_D_qD
Front shocks
http://www.socalsupertrucks.com/fox-2-0-performance-series-ifp-shock-chevy-gmc.aspx#.VbGNB5_D_qD
Rear shocks
The reason I looked at Fox shocks was bc I have never heard anything bad about Fox. I'm sure there are some negative comments on Fox, but I haven't heard any
It's hard to over-do it with suspension components--there really are gains to be had with better stuff. Fox is good stuff, but for a pavement rig their strongest attributes are sort of going to go to waste. Another option that might suite you a bit better is ICON. I'd recommend this for you: http://performancetruckproducts.com/k73001-icon-2007-current-silverado-sierra-1500-suspension-system-stage-1 . You will not believe the ride and handling. If you went offroad more I'd recommend the extended travel coilovers combined with new upper arms (for either Fox or ICON) for more travel.
How is the stock setup or the bilstein setup different than a coilover? Aren't they all coilover configurations?
Im not exactly sure how they differ, but I know a coil over has the reservoir on the top. OEM setup has the reservoir on the bottom.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
