Rams are 150w.too.
Fords 400 watt inverter :)
Nothing is perfect for everyone..
400W is still useless.
400W/120V=3.3 amp
Normal household 120v circuits are 15A.
My direct plug in will not charge my laptop. Dealer says it's not meant for that.
  • 2 years later...
My question is, does anyone know where this inverter is actually located. Plan on swapping out and adding a second battery. Would like to know the location so i dont have to go on an easter egg hunt. Id imagine being 150w that its probably buried somewhere in the console or dash cause its so small.
  • 6 months later...
Its 400 watt can run anything that pulls less than 400. Best is anything that pulls 200 or less.400 watt pull will probably pop the fuse. Alternating current is in waves low and highs D.C. current is a constant. No peaks. I'm a truck driver and use a 2000 watt inventor in the truck. Also keep on mind anything that produces heat. Blowdryer heater heat gun pulls a lot . check out the item to see what it pulls.and Will have to run the pickup to keep from running the battery dead. Personally the idea of a 400 watt 110 in the bed is s bad and not very useful idea
  • 8 months later...
On 7/28/2015 at 1:08 PM, Texas Sticks said:
Okay. Here's the equation:
P=VI (Power (watts) = Voltage (volts) x Current (amps))
With the numbers provided above, the available current (I, in amps)
should be...
I = 150/12 = 12.5 A
Yes, I am a physics nerd.
Yes a nerd....but most nerds are intelligent, which apparently you are not!
should be...
I = 150/12 = 12.5 A
Edited by CliffyCan
On 7/28/2015 at 11:24 PM, Newell33 said:
Yes, I understand the equation and the relationship. What I'd like to see is a 350w inverter. This would allow for about a 3 amp outlet, which would be adequate for that 18v charger that we talked about earlier. Yes, this would be about a 30 amp load at 12 volts. Assuming the inverter is behind the socket in the dash, and the wiring being no longer than 8-10 feet routed (probably less),10 gauge wire could be used. I know copper is expensive, but it would be nice to have something a bit more powerful.
What everyone is neglecting to see here, is that the current out in AC is 1/10th the 12VDC current. So sure, everyone wants to gripe and complain that 1.25A/150W IS TOO SMALL. So double that, you have now effectively quartered or worse the remaining current from the alternator. The battery can handle loads well enough,  but in worse weather, and several starts/stops, it could get dicey. I know my outlet only works with the truck on. Hook an inverter directly to the battery, and you are asking to be stranded in a parking lot somewhere when you forget to turn it off. Car design is all about managing the balance of creature comforts, production costs,  and efficiency,  while minimizing service calls and warranty repairs.
  • 4 months later...
On 7/28/2015 at 1:59 PM, sahls01gmc said:
^^^^^^^^^ 150 watts = 120volts x 1.25amps.
The inverter only puts out 150 watts.
the inverter puts out voltage.   current is the amount of electrons flowing.....the correct way to say this is 150 Watts is the max current allowed before its breaker cuts it off (to protect wiring and other components from melting).     150W?    That's it?   This is quite disappointing.     My new 21 barely allows 130 watts.    I've got a laptop plugged in and the power adapter has a max draw of 130.    The first couple of times I plugged it in the internal breaker tripped it.   A few four letter words were said and it must have heard me because it started working.    At first i had both laptop and printer plugged before know the max draw through this outlet was 150w and it wasn't having it.     I think i'll have to run to HF and buy a power inverter that will allow my printer as well.
  • 2 years later...
should be...
I = 150/12 = 12.5 A
Sorry physics nerd, but the proper calculation is 1.25 amps!
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
    • I think the ship has sailed on the fuel injection type - everything is getting direct now.  Does it help with mpg?  Not really and nobody buying a HD truck really cares anyway.  But that is what it is at this point.  Piston rings is something they may well adjust over time to get them right.
    • I don’t have detailed measurement data, but this past March we were hiking and camping in Death Valley and the Las Vegas area when this Spring’s heat wave hit with 105 plus temperatures and our 2021 L8T system kept our crew cab as cool as we wanted it (68F setting) with no trouble. Fan flows on auto once stabilized were fairly low. It seems like the OP’s system should be performing better.
    • Yes that's correct on the route to Durango - we just followed what google maps recommended.  That is quite the pass btw - very steep going back down.  I didn't even need manual mode - I just used cruise control and set the truck at 50 I think when it was a 45 posted speed and for the most part it just held it there by keeping it in the right gear - everyonce in awhile there is a sharper turn that I just braked for - but it was pretty smooth going down it on both sides.  Amazing views around there for sure - we had no real time to stop, were on the clock for a set-up time, but we did stop in some 2 horse town somewhere a couple hours oustide of Durango in the middle of nowhere for burgers.   And yes - lots up up and downs on the Durango trip but I think it's a big difference going 70 vs. going 80-83 with the aero in play with these big trucks.  Even the much smaller Colorado does reallt bad on gas going up over 70, I think I would have been lucky to get 18 on that trip in the Colorado honestly.  The full size is definately more comfy for a long road trip too, and the amount of gear we had would have meant two vehicles if I still had the Colorado.
