How many trucks DONT vibrate?
People don't post up when there are no issues, but they do post 100 times in the issues thread... Just my thought. I'm looking at 16s and these vibrate threads are making me nervous though.
No interest in the competitors offerings either. Not because they're not GM, but because of design, feature or powertrain options. The 16 Sierra All Terrain just nails it in every category. As long as it doesn't vibrate.
And what so attractive about GM powertrain options? They installed that stupid AFM on every engine they offer in these trucks now and to get the 6.2 engine, you must go with the LTZ or SLT trim which not everybody cares for, or wants to pay thousands of dollars extra for, and then they charge you $ 2000 extra on top for the engine upgrade alone over the 5.3 engine? This is a totally shameless ripoff. There is no reason why the 6.2 engine should not be available on LT or SLE trim level for $1000 extra. I think that's what it cost back in 2010 or so.
  • Replies 200
Had a vibration on my brand new regular cab silverado...i took it to a local tire shop that I trust and had the tires balanced. Vibration is gone.
I am not getting any vibration that I notice really. I am generally on a lot of rough roads though commuting (I-605 & I-5 area of So-cal) I am only at 3k miles though too. So, I don't know if I could tell the difference honestly if it was my truck or the road. The very few smooth roads we have in the area though don't lead me to believe I have experienced any vibration issues... yet... knock on wood as the saying goes.
My 2011 use to vibrate at that speed. I took it into the dealer twice. First, they rebalanced. Second, they changed out the tires. Once I put my lift on, I took those retaining star washers off of the brake drum and no more vibrations ever since. Weird.
I'm about to trade my double cab for a crew for more room and just to get out of my vibrating truck. The dealership is giving me the run around and I'm just not in the mood to fight. I'm getting one heck of a deal with a special going on right now with 13k off SLT trucks but I'm afraid the new one will do it too. Test drove 4 trucks total and 3 vibrated at the 72mph mark while the other was butter smooth.
How many don't? Just post yes or no.
Thanks
Just took delivery on a 2016 GMC Sierra Double Cab SLT/Z71...SMOOTH RIDE!!
8 on the scope is noticeable. Just brutal what's with these trucks. This isn't the only forum that has a section on this.
I feel your pain.
Mine was..... then I realized that I have always had trucks vibrate because with snow, high pressure washers, ice and mud those stick on weights just don't last... I am at 8000 miles since new tires. So I took my truck to the Ford dealer I bought my tires from and had them rebalance all 4 as with no surprise they were out.... and it rides fine again lol.
Mine, thankfully, is only slightly noticeable at 80+ and only when the truck is low on fuel (light payload). If I have half a tank of gas or passengers I don't notice it at all.
When mine goes into v4 at low speeds you can tell and the vibrations are there but not that a big a deal
I think its the cylinder deactivation thats causing the vibration issue in my truck. Once it hit 300 miles, it started to be noticable. Do keep in mind, the engine is basically missing the entire time its in V4, so its not really crazy that it can be felt. Still annoying though........
5 friends and myself have 14+ chevy's or gmc's. We have talked about it, and none of us or none of our friends friends know anybody with this issue. Percentage numbers must be pretty low. On that other poll thread, only 8 out of 600+ hate their trucks. Real numbers speak volumes, its a pretty darn low percentage.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 482 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
