aftermarket exhaust question
I want to put a cat-back exhaust on but my exhaust guy said that it might sound bad when it goes into v4 mode. Has anyone have this problem? Thanks in advance.
  • Replies 33
Your dealer is absolutely correct and Just about everybody in here has that problem. Tons of info already posted in here...
There are exhaust systems that have no drone, some that are unbearable and a crap load in between.
Sent from Off Driller Side
I've been doing research well before I ordered my silverado. And I'm gonna try and do a exhaust set up. If it sounds good I will post pics and video.
Yes. it sounds bad. Dubbed the helicopter noise. It sounds like a misfiring engine. I had AFM tuned out of my truck so it never goes into V4 mode. Sounds way better at all speeds.
No drone in V4. Borla ATAK dual out the back. 6.2L.
I think you're confusing drone with the V4 engine note. Drone is when one certain frequency of sound becomes shrill and hurts the ears. The V4 engine note just plain sounds bad. Not sure if the Borla kits have an internal flapper valve to mitigate that noise.
Magnaflow - the flapper + keep the resonator = no helicopter noise
I'll second that.
By any chance can you post a video of start up, some throttle, wot.. and what kind of MagnaFlow was used
A video of the magnaflow would be nice. I want a little rumble but not too much. How is the cabin noise with this setup?
I am also interested in a video of the Magnaflow. Also what size ( 14-18-22)? And is it a single outlet or duals ?
I seen a couple on youtube. One of them sounded stock and the other's sounded slightly louder than stock. And one sounded good but he removed the 3rd cat and had no flapper and no resonator
