All Terrain 20" wheels in winter
Does anyone out there run their All Terrain stock 20s on their truck through the winter months? How do they hold up from the salt/sand? I'm contemplating whether getting a cheap set for the winter is worth it.
I'm gonna guess that 90% of people run them in the winter. If you take care of (clean / polish) your wheels, they'll stay looking good.
Ran mine all last winter. No issues with sand or salt. I washed my truck about once a week in the winter and made sure to give them a decent cleaning in the springtime. They had a couple little pits in them but it could have been from driving down a gravel road in the summer too.
It's a truck, not a sports car with $500 chrome wheels.
Awesome! Thanks guys. I'll just be sure to spray them off on the regular!
Did you run your OEM tires in the winter last year?
I ran stock tires and wheels last winter with no problems. Got Toyo MTs in the spring and drive on the beach all summer long. So my truck sees salt and sand year round in Delaware. No problems so far.
Just like anything on the truck, over time winter will take it's toll and it will start to show. But nothing on your truck will last forever anyway.
The only issue I had was from ice and snow build up. They would vibrate like mad until it melted or I ran it through a carwash.
But they held up ove the winter well.
Make that 99.9% of all-terrians using stock wheels year round.
Run them, they are clear coated, don't let tire shops install outside wheel weights, don't curb them, and keep them clean and they should last a very long time.
Yup factory Goodyear SR-A's.
I'll wear them out and buy some actual AT tires when its time.
I bought my truck in January. The wheels saw a fair amount of slush and salt. I tried to make sure the salt didn't stay on them too long. I didn't do anything special except hose them off now and then. They look fine. I'd be more worried about the lousy Goodyear tires. It's a shame to put those tires on a truck labeled All Terrain.
Got mine in March. Ran the stock wheels and tires through the winter/snow. No issues. This year I'm covered....in plastidip.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
