Front Air Dam
Countless people here and hundreds, if not thousands more I've just happened to pass have the stupid thing removed and no one is overheating. I pulled it off my 2011 within the first week I had it and drove it for about 75k like that. The new trucks would be no different.
  • Replies 47
As previously mentioned the trucks rad is sealed to the grill...... it's function has zero to do with cooling. But the poster of that BS also can't figure out why 6.2's operate better on premium gas among multiple other things he openly cannot figure out nor wants to listen to anyone else's opinion or facts..... If no one notices he will usually post something stupid once per thread to stir the pot and leave.... that is what you call a troll....
Pull it off and enjoy not dragging it everywhere you drive that isn't paved. You should see the trucks operations run up here and you would laugh. I am pretty sure not one of them has a valence that is still completely intact if not already torn off.
Cracked mine this past winter driving thru snow drifts. Going to remove it sometime before the summer is over.
Sent from my iPad using Tapatalk HD
Is that a trimmed down air dam? Seems more cosmetically pleasing that outright removing it. Just getting ideas what I want to do.
People have removed them completely and it exposes the multiple mounting tabs so instead of dealing with that eyesore that I know would annoy me. I just trimmed it to be more appealing to me.
  • 2 months later...
What utensil are you folks using to trim with?
We used a reciprocating saw and a pcv blade. Brother runs a pool company and is very handy with that saw, cut almost a perfect line where I wanted it with no melting or anything. Quick and easy. We did it off the truck since it was already off at that time but doing on would work great if not better as it would be more rigid when cutting.
Tyler
I took mine off nicely before I ripped it off and it took other things out with it.
Took mine off a month after I got the truck and haven't had one issue in the two years since.
This. Damn think is held on with so many bolts and clips it just may take out or damage the whole bumper if you hit something good.
The damn dam is cracked on my 2012. Going to be taking it off soon. high snow drifts did mine in.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
