Warranty work for a factory issue but have custom tune. (replacement t
Good luck! I would give you about 50/50 odds on this one. Hope it works out, especially since it is a known issue. They replaced my transmission under this same bulletin and it cured the clunk for the most part. Still has terrible shifting at times with a jolt to go with it and it causes a bit of a clunk in the rear end, but overall the transmission noise was cured with a replacement transmission.
  • Replies 33
If you can I would put the factory tune back on before taking it in. Don't give them any more ammo than they already have. But with this being a KNOWN issue they better not even think of denying coverage simply because you tuned to make the truck respond the way it should in the first place. Don't take no for an answer
With there already being a TSB I highly doubt you will have issues. I would put it back to stock just to make sure the flash doesn't have any issues though
Ryan
Well, I guess we will find out soon enough. (Fingers crossed)
Sent from Off Driller Side
The wait begins... Dropped truck off at 7:30am this morning. First thing service guy said when I walked in was "did you get the factory calibrations back in it?" [emoji6]
Not like that's going to help any but it's just nice knowing I got a helluva dealership to work with after hearing all the nightmare posts about other dealers.
I'll update as I get info.
Good luck. Shouldn't be an issue since there was a documented TSB issue with that specific transmission. They really shouldn't even think twice.
Update us as you know more!
It shouldn't be an issue at all. Already been through this with a Denali that had a pile of bolt-ons and tuned and had a much larger problem than what you have.
You're in TX, totally different ball game- no idea how dealers out there sell these heavily modified new trucks without blinking an eye, but that ain't the way it goes in the rest if the country....consider yourself lucky!
Although the OP is in OK so may have some similar attitudes out there.
I agree, I love this state.... and for those of you that don't live here... stay where you are....we are full...LOL
I am just guessing but . . .
Dealers make money when they do warrantee work. So, the dealer wants to do the work as much as you do.
My guess is that the dealer will try to get it approved, and not go out of their way to say that the truck was tuned.
Again, just guessing!
They would have to prove the tune caused a problem they already admitted to. Take it in. They may note records of a tune for future problems. say you throw a rod etc...
Picked it up yesterday.... Just because they are willing to work on it doesn't mean they know what they are doing.
To some it up, they say the issue is either in my exhaust or my leveling kit ( went right to blaming aftermarket parts).
They did however grease my leaf springs for absolutely no reason, besides trapping more dust and dirt that will eventually cause premature wear. I have already clamped the springs off so I'm surprised they didn't mention that.
I'm not going to fight with them, I'll put truck back to stock and take it back.
Wow. That sucks. What does exhaust have to do with a known transmission issue?
It's simple, he comes to work to get a check.. Not to earn it and the simplest thing to do was throw his hands up and say... Woah! Aftermarket parts!
I'll put it all back to stock and record my next conversation with him next time just so I can post it on YouTube.
To be fair, I'm not 100% sure it's the transmission I just suggested to them that I have the exact same issues as the bulletin describes and that I have done everything I can to try to eliminate any other possibilities. IT IS DEFINITELY NOT THE EXHAUST and I'm pretty confident that it's in the transmission.
It just baffles me that they will dismiss a bulletin to blame an aftermarket part .
If I find a place that will upgrade this transmission by January, I will just go that route.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • NewDude, thank you for the suggestions!    I did follow up and the dealer indicates he has an open CX case and is working with DPAC (Dealer Parts Assistance Center).   Per the dealer, GM has had a quality spill and is not providing an update for when a replacement engine will be available.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
