Looking to actually gain some MPG
He asked for better MPG, disabling AFM is the opposite of what the OP is looking for...
OP, take off the lift, that will help. You look to be nose high (or possibly level) so that ruins some of the aero on the highway. Having stock tires your city mpg won't change much but it will help on the highway. Keep the valence too, it was put on there for the reason of better mpg and directing air away from under the chassis (that is a large point of drag) and tires at highway speeds; the lift puts that stuff more in the air. You won't gain back a ton (maybe a MPG if that was lost before) but you will gain back some and you will save your front end components from premature failure.
Tyler
I was getting the same if not better mpg with afm disabled. It keeps the truck from bogging down and struggling when it wants to stick in 4 cyl. mode
  • Replies 127
It's a truck...with a big motor...designed to tow and haul things. Sell the truck and your problem is solved!
Edit: sorry, I do see you mentioned you are aware of what I just said. I'll say this then...accept it haha. This is just my opinion as everyone has different expectations and uses of their own trucks. I buy trucks bc they are the best all-round vehicle. I can carry my family, tow my bikes, haul anything, go off-road, Yada yada...they do it all. For that I will gladly accept 18mpg city and 22mpg in stock form, and I will also accept that if I alter the height and aerodynamics a tad; worse mileage. It's all how you look at it. On my lifted 07 (5.3), I fitted it with an intake and exhaust. I did actually gain 1.5mpg (according to the DIC) I put a 2.5" inlet/outlet muffler onto a 3" pipe with a reducer. Added a slight amt of back pressure and that seemed to help the truck. Just try not to lose your mind searching for gains, b/c you might not get them. Enjoy the truck you bought with your hard earned money.
1) Vacuum gauge
2) Lower it
Driving style is huge. The vacuum gauge will show you how to use as little gas as possible to get moving. Don't use cruise control, accelerate downhill, back off the throttle uphill.
two words.... forced induction.
That is if you can keep your foot out of the throttle and drive conservatively.
impossible! :crazy:
There was a post from some guy on this forum that claimed 27ish highway mpg on his supercharged truck. Wish I could find the thread.
OP complaining about 19mpg average guys...this thread is moot.
Kinda what I was thinking, I get like 15.5 uncorrected though
I average 16 in town, about 17-18 highway. Never seen, over the course of a full tank, anything greater than 20mpg average. That was also all mountain driving which I thought was pretty good for cruising 80mph
As said before, Watch the instantaneous mpg screen, it will teach you how to drive for best mpg.When possible coast. These trucks are heavy vehicles and have alot of inertia,use it ! Keep tire pressure up , 38 psi +. Top tier fuel if it dosent cost extra. (87 octane is fine). Full synthetic oil might help,not sure? And remember to forget about mpg once in awhile and drive for fun and enjoyment.
This but I would recommend using at least 89 octane. The Direct Injection and High Compression ratio will thank you.
Full length Running Boards haven't been mentioned. The keep the airflow separated between the side and dirty air on the underside of the truck and increase CD and gas mileage.
A Tonneau cover will help here's an article on actual wind tunnel test: http://www2.sema.org/main/semaorghome.aspx?id=57514
On average, we found that tonneau covers improve the coefficient of drag by about 5.7%. Although other tests would need to be conducted in order to determine the exact effects on fuel economy, we can use an aerodynamic “rule of thumb” which states that a 10% improvement in aerodynamic performance translates to roughly 2%–3% gas-mileage improvement. Therefore, an improvement in Cd of 5.73% would translate to roughly a 1.8% gas-mileage improvement.
Im running a 2inch level + 33" nitto terra grappler All terrain E rated tire on XD 22"s and took a road trip last weekend. I got 19-20 mpg on the interstate. I get about 15-17 around town
Thank you man thats actually pretty reassuring. I thought it would go down to 15 across the board. Do you think a 3" compared to a 2" will make that much of a difference?
Might have something to do with the hills out there, mine here in flatter Texas jumps 2-3 mpg when it clicks in to 4 cylinder mode on the highway and stays there for even slight inclines. When I first got it, it was a fun watching the mpg and mode around town, on the highway, coasting to a stop or down hills. It seems to stay in 4 cylinder mode until down to 10-15 mph before going to V8 when coming to a stop. If they made these new trucks stay in it longer, I wonder how little it would switch in the last gen? I heard it barely ever would.
Tyler
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
