Looking to actually gain some MPG
Hey guys thought I'd check back in. Believe it or not I just filled my tires up a couple extra psi to 37 and it actually helped out to keep me at 20avg. I do drive like a grandma so I guess that helps and I know my tires might wear a little more but I'm looking to get some more aggressive ones eventually anyways and it will prob only take maybe 500-1000 miles off the tires. Has anyone here tires nitrogen filling tires? Goodyear is pitching that it helps with mpg but I'm skeptical....
  • Replies 127
Also can someone please explain the differences between what the truck identifies PSI at and what the Tire does? My truck says 32psi but the tire says it can take 50? Sorry I'm kinda a noob
32 is what gives the best ride. 50 is what the tire can handle before it could potentially be damaged from over inflation. (It's probably actually higher.)
If you plan on getting more aggressive tires then why even bring the MPG thing up? You will lose 1 to 2 mpg when you go with the more aggressive tread and a heavier tire.
The only benefit you will get with nitrogen instead of atmospheric air in your tires is the fact that the pressure in your tires does not fluctuate with temperate change. So in a sense, I suppose your fuel economy would improve if temperatures change quite a bit while you are driving.
Rule of thumb is for every 10 deg. F. change in temperature, your tire pressure can vary roughly 2%.
There are many occasions in Kansas when it will be 65 deg. F. one day and drop to the 30's the next. 2-3 PSI fluctuation is quite a bit especially if you plan on doing a lot of driving!
With gas as cheap as it is now, mpgs are low on most car owners mind. Note the drop in hybrid sales and the rise in truck and SUV sales. Surprised this thread has this much action.
Then someone, such as myself, who uses their truck for towing will not be able to tow what they need to. You'd be going to a higher gear (lower numerically) causing the truck to struggle. We shouldn't have to modify our trucks to keep them from shaking lol
I am not saying go out and get really high gears but lets say the OP has 4.10 gears if he was to put in 3.08 I think is what is below the 3.73 and 3.42? he would still be able to tow here and there and not loose too much in the long haul. My wifes suburban has 3.08s(again I think that is the number) and it tows our two boats just fine as well as our dirt bike trailer. I get .5MPG less towing with her 2011 Burban than I do with my 15 Silverado, I believe I have the 342 gears
I try to keep my tires filled to around 43PSI if I am going off the road I will lower it. I used to have an 03 tundra with Firestone tires that were rated for 80PSI, when you get up to 70PSI you can tell a difference in the ride
On these new trucks the ones with 3.08 gearing can tow like 6000 pounds. My truck with 3.42 gears is rated to tow 9800 pounds. Obviously it varies based on cab and bed configuration, engine size, etc. but that is a huge difference. And even though the trailer may not be but 5000 pounds the truck with 3.42 gears is gonna tow it much much easier than the truck with the higher gears
Edit: I thought this was the shake and vibe thread which is why I said something about them shaking. Whoops, guess my eyes deceived me again [emoji23]
If you have OEM tires, the 32 psi is what the GM recommends for best ride, and tire wear.
You need to check the tire sidewall and see what the MAX psi rating is. If you are on stock tires, you may be close to the max at 37.
First, please explain how the installation could harm the vehicle. Please be detailed and technical. ALL Elite (and several other cans) retain factory warranty as well as retain emissions compliance.
2nd, Elite is a supporting vendor, and even though there are a few others that test close, none exceed it. So w/out supporting vendors the forum cannot exist.
3rd, please explain Tyler how reducing knock retard would NOT improve fuel economy (I explained how it does and even the most amatuer tuner can verify this).
On the range of 1-3 that is the actual range they are comfortable claiming even though many examples got better, the majority depending on port injection or GDI and the make/model/engine the range they can guarantee is 1-3 and that is what large fleets that run these first verified (the deal is after verifying it is an actual fleet manager or owner, the first system is provided at no cost so they can track and verify).
And Grainger is just one of many that have verified the claims. They are bombarded by every snake oil "turbonator" and "magic magnets" and are not easily giving time to even listen to pitches much less spend the $ to equip several hundred light trucks or vans with these.
Now, please be detailed and explain how this would not. I explained how it does and it is common sense. ANY oil contamination of the air/fuel mixture will disrupt flame front and burn pattern, slow the combustion, and release less energy. You only want air and fuel present. So, if detonation is detected by the knock sensors timing is pulled until the rate of knock per second is below the threshold in the KR tables.
Now, on harming the engine? How in the world could that be? Unless you defeat or delete the functions of the PCV system, there can be no warranty questions, and also can only be beneficial.
Look at any of your trucks intake valves if you have over 15k miles on it and see the wear to the valve guides form the hard crystalline deposits are pulled into the guide with every cycle. How the build up disrupts flow and velocity. With GDI, the coking rate is always heavier on the valves closest to the point of ingestion, and the valves the furthest are less effected yet the upstream O2 sensors are reading the average of all cylinder for that bank, so the PCM is commanding equal fuel delivery into each cylinder so the ones with more severe deposits are running richer as there is less air entering that chamber, and the ones with the least are running lean so that is not optimum operating. The engine is never more even and efficient then when the ports and valves are deposit free.
Read this long term independent test performed by a UPR customer over several thousand miles and 3 months of documenting:
5.0 UPR vs E2X Catch Can Effectiveness Test
I’ve had a UPR catch can on my 5.0 since last summer. It catches a lot, especially in the cold months. But I’ll get right to my test. I added an E2X can inline after my UPR can to see if the UPR was missing anything. And if it was allowing some to pass through, was it enough for the EX to catch anything? I don’t drive a lot of miles regularly since my F150 is not a daily driver, so my results will take some time. This thread is to document how I set it up and what I catch over time.
I installed the EX can just as the directions explained, but I routed the hoses differently. I left my UPR can right where it’s been for months, but rerouted one hose. I left the hose from the passenger side of the engine to the inlet of the UPR can. Then a new hose from UPR can outlet, routed to the inlet of the RX can. The EX outlet hose goes back to the engine. The PCV exhaust now flows from the engine, through the UPR, then through the EX, and finally back up to the engine intake.
Before installing everything for the test, I cleaned the UPR can thoroughly. The bottom of the can (inside) was covered with a thin layer of stiff sludge that I could only clean out using gas. I’m glad that was caught, along with the ounces of oil, water, etc, over the months I’ve been emptying it. But I was surprised at the outlet hose from the UPR can. It was wet with oil. Obviously some was getting through the can and back to my intake. I’ve never let the can get close to half full before emptying it. Nearly every time I’ve emptied it, there was 1/4“ or less in the bottom. I’m noting this in case someone thinks I left the UPR get overfilled and it flowed through. Nevertheless, I started this test after cleaning everything for a fresh start.
I plan to leave this setup on for a thousand miles or so, and report my findings from each can.
1st picture: UPR can as it was originally installed.
2nd: CleanUPR can.
3rd: EX can installed. The hose in the top center of the can is the inlet. The outlet hose on the right has a check valve.
4th: Engine outlet to UPR inlet on left of can. UPR outlet on right side of can routed around (smaller hose) to the EX inlet. You can also see the other smaller hose coming back up from the EX can and ending at the intake on the engine.
Report 2:
I thought I'd add a post to keep this thread alive since it is taking me awhile to get enough miles on the truck for valid results. Now that spring weather is finally arriving, I haven't been putting as many miles on it since I'm busy. But I have around 600 miles on the test set up so far. I emptied the cans recently and recorded the volumes to date. I'd like to wait until I get to 1000 miles before posting the results from the test, but I'll give some preliminary feedback.
- Emptying process -
First the UPR. I'm used to emptying the UPR can regularly, so it's not a big deal to unscrew, guide the can out from between the hoses, pour it out, guide it back in between the hoses, get it lined up carefully (so I don't cross thread the soft aluminum) and screw it back up snug. All that takes less than a few minutes so it's rather easy.
Now the EX can. Raise the hood, hold an empty water bottle under the drain tube, open the valve, close the valve, close the hood. I kid you not, it takes no more time than it took to read those steps. I knew it would be easy to empty, but it is ridiculously easy.
_ The weather so far -
During the first week of the test we had winter weather, with some snow. Since then we have had mild weather. Temperatures are in the 50's and 60's most days.
- What they caught so far -
I won't share the amounts yet, but I'll give some info. The UPR can has caught a 'mostly oil with a bit of water' mixture so far. The EX can (in line after the UPR) has had just the opposite. It's collected mostly water or fuel, with some oil mixed in.
I emptied the UPR first, and I would estimate it has collected the normal amount compared to what it usually does I empty it. I was pleased that my set up with 2 cans didn't seem to change the normal flow and collection I was used to seeing with just the UPR can. When I was about the turn the valve to empty the EX, I paused to a few seconds wondering if anything would come out. After all it was a new can that would need to get some oil/water coated on the inside before there would be enough to drip to the bottom (The UPR can had been in use for many months and although I cleaned the can I did not rinse off the filter material). Plus I wondered if the valve of the EX can protruded up into the can, and if it required some liquid to collect before there was enough to spill over that valve nipple and exit the can. Then I opened the valve and I had to smile when I had some liquid drain out. I thought all along that if it caught more than 10% of what the UPR was collecting, I would be surprised. It's still early in the test, and I would like to redo the test after reversing the order of the cans later, but I am surprised so far. I'm hoping to get more miles on the truck soon so I can wrap up this phase of the test.
Report 3:
1000 Miles of Testing Results
- The Weather has been warmer lately. So the test began with sub freezing temperatures, and gradually increased through the 70's and topped off in the mid 80's yesterday. I couldn't have asked for a better range of temperatures for this test.
- What they caught was astounding to me. UPR was first in line, with the EX after it to catch anything the UPR might miss.
The UPR stayed on track with what it has been accumulating for many months. Each time I emptied them, it had about the same amount. It's contents were mostly oil which smelled like used oil. It caught 17cc total which is just under 3 1/2 tsp.
The EX had more than the UPR each time I emptied them. It's contents were an oil/fuel/water type mix that had a much stronger odor. Not a fuel smell, but a sharper chemical smell compared to the odor of used oil. It caught a total of 67cc which is just over 13 1/2 tsp.
- Final totals:
UPR - 17cc
RX - 67cc
The EX can caught 4 times the amount the UPR can caught, after the UPR can removed what it could. I said from the beginning I would be surprised if the EX can could pull 10% of what the UPR caught, since it was second in line. If someone told me it would catch an equal amount I would have said BS. For it to catch 4 times what the UPR can caught is unreal.
Report 4:
The routing of cans has been reversed so the second phase of the test is underway. I cleaned the cans and hoses so neither has an advantage. I also checked the inside of the hoses as I disassembled everything. The exit hose from the UPR was dripping with oil and it made a mess as I took it apart. The exit hose from the UPR was clean and dry. It still looked new. That is what prompted me to clean all the hoses before starting this phase. Is the double can routing helping the second can that much, or is one can that much better. Time will tell again.
Report 5:
And now back to our regularly scheduled programming…
Phase 2 is almost complete now, thanks to some extra mileage for work. I'll report on that soon and begin phase 3.
As I said above, UPR shipped parts for me to do phase 3 of the test. I bought my UPR can in June, and they changed the can slightly since then. The new diffuser/extension will only fit cans made after that, so they shipped a full new kit to test. Thank you UPR for helping with this, and for your input in this thread.
After shipping the kit, Joe@UPR asked me to remove the mesh from the exit side of my existing can for the remainder of phase 2, and to remove the mesh from the exit side of the new can before starting phase 3. I removed it from both (phase 2 was half way done when I removed it from the existing can). When I was removing the mesh from the short side of the new can (in preparation for phase 3), I realized the diffuser was assembled backwards. For our 5.0 F150's the long side of the diffuser must be on the passenger side of the can when installed. I disassembled, removed the mesh packed up in the can top on the exit/passenger side, and reassembled the can with diffuser. For anyone who might have received their cans assembled by UPR, you should check to see if it was assembled correctly before installing. (EDIT: Joe notes below they assemble the cans for shipping, and all cans should be assembled for your own installation needs) I also had a small piece of the stainless steel mesh (1/8") drop out when I was doing that. I wasn't thrilled with that so I unrolled, and lightly tapped the mesh in case there were any other loose pieces, but there weren't. A quick note on the UPR kit... it is much improved since I bought mine. The hoses are pre cut to the proper lengths, the elbow fittings are nickel rather than plastic, and they include Ford OEM snap on valve cover and intake fittings.
More to come soon!
Report 6:
Test Results
- I'll summarize the test to date. The first phase was to test the UPR vs the EX catch cans on a 5.0, both base models, with the UPR first in line and EX installed to catch anything the UPR missed. Those first phase results were: UPR - 17cc, EX - 67cc. The 'first in line' UPR caught 20% of the total volume. See post 37 in this thread for more details. The cans were cleaned and reinstalled in reverse order for phase 2, EX first and then UPR.
Phase 2 Test Results
- The Weather has been average northern Ohio spring weather. Some rain, fog, cool nights, warm and hot days.
- Driving has been about the same through both phases. I good mix of rural roads, some small towns, highways, and approximately 40% of the miles on interstates at 65 - 80mph. Mostly average style driving, with a few very heavy accelerations mixed in. A little heavy hauling, and no towing.
- What they caught this time might have been predicted by some (after the results of phase 1). EX was first in line, with the UPR after it to catch anything the EX might miss.
The combined volume of gunk was half of that caught in the first phase. The first phase had some cold weather which accounted for more water in the mix and the higher volume.
The contents from the EX can was mostly oil/fuel, and had a strong chemical/solvent smell again. It caught 35.5cc total which is approximately 7 1/8 tsp.
The UPR can caught about the same mix of oil/fuel, but didn't smell quite as strong. Halfway through this phase, Joe@UPR asked me to remove the mesh on the exit side of the UPR can. I did that, but noticed no difference in what it was catching. But since it was second in line, and there was little to catch, that's understandable. The UPR can caught 1.75cc total which is approximately 1/3 tsp. With so little collecting this time, I monitored the contents of the UPR can but didn't empty it until the end of the test.
- Phase 2 Totals:
EX - 35.5cc
UPR - 1.75cc
- Other tidbits include the 'first in line' EX can caught 95% of the total volume. The exit hoses were very clean from both cans. The last few tanks of gas have produced slightly higher than my normal MPGs, but it's too early to tell on that (more to follow after phase 3).
-Phase 3, using the UPR can extension and diffuser, is underway. Details will follow.
Final Test Results
- I'll summarize the test phases. The first phase was to test the UPR vs the EX catch cans on a 5.0, both base models, with the UPR first in line and EX installed to catch anything the UPR missed. Those first phase results were: UPR - 17cc, EX - 67cc. The 'first in line' UPR caught 20% of the total volume. See post 37 in this thread for more details on phase 1. The cans were cleaned and reinstalled in reverse order for phase 2, EX first and then UPR. The second phase results were: EX - 35.50cc, UPR - 1.75cc. The 'first in line' EX caught 95% of the total volume. See post 143 for more details on phase 2.
Phase 3 Test Results
- This time the UPR can was first in line as in phase 1, but it had the new can extension and diffuser added. It also had the mesh material removed from the exit side of the can.
- The Weather has been average northern Ohio early summer weather. Some rain with warm and hot days.
- Driving has been a good mix of rural roads, some small towns, highways, and approximately 60% of the miles on interstates at 65 - 80mph. Mostly average style driving, some steep hill climbs, and some very heavy accelerations mixed in. A little heavy hauling again, and no towing. I'll add some more thoughts on driving and MPGs below.
- What they caught was a mixed bag. UPR was first in line, with the EX after it to catch anything the extended UPR might miss.
The combined volume of gunk was down from the last phase, again. I assume it is due to the warmer weather and maybe my engine is using less oil with more miles? Either way, my test looks at the percent each can catches, compared to the total caught for that phase, so the volume isn't critical.
The contents from the extended UPR can was mostly oil, and had a used oil smell. The UPR caught 14.75cc which is approximately 3 tsp.
The EX can caught a fuel/water/oil mix. It smelled much more harsh again. The EX can caught 16.00cc which is approximately 3 1/4 tsp.
- Phase 3 Totals:
UPR - 14.75cc (48%)
EX - 16.00cc (52%)
- Other thoughts on the results. The contents of each phase showed me the EX does a better job of removing more than oil. It always contained more water/fuel type liquids, while the UPR contained mostly oil. I don't know if it is due to the can design, the 'out front' mounting style of the EX, or both.
For anyone buying or thinking of upgrading their UPR can, I strongly recommend figuring out how to mount it out front, and would definitely add the valve that Joe@UPR is offering. I really think the 'out front' cooling effect will help it catch even more, and the valve would be worth the price for ease of emptying it. Having the EX can to compare to when emptying, the front mount and valve are no brainers.
As I said at the end of phase 2, my MPGs have increased slightly. I have done nothing different to my truck over the past year, other than adding the EX can to the UPR for this test. My driving style is very similar from tank to tank, I fill up at the same stations, etc. But since having both cans in series, and essentially removing 95% or more of the PCV byproducts, my MPGs have increased. Up to that point my lifetime MPGs were 17.5. Nearly every tank for the past year gave me the same results, 17.5. I would have some trips that would net 20 MPG, but the other short trips would always pull it back down for the same tank average - close to 17.5. My recent tank averages have all been over 18 MPG, with a few over 19, and as high as 19.5. My last tank included hauling approximately 1000 lbs of payload, through some long hills/mountains of PA, and I got 18.8 MPG. It could be the summer fuel mix combined with an engine that is broken in, but the timing is peculiar. Whatever the reason, I like it!
That is one of many done independently. So. lets have a civil discussion on the technical merits of your claim, and the same from me. Working for over 4 decades as an Automotive Engineer, and focusing on GDI issues since 2008, I can assure you I have lived and breathed this closer and more personal than most and am happy to provide my credentials and qualifications if that helps. This is what I do for a living day in and day out and as a member of SAE (International Society of Automotive Engineers), I have access to a mountain of industry data as well as participate in technical forums and discussions on all of this in great detail on a regular basis. The firm I work for is contracted by several tier 1 suppliers to the big 3 US automakers as well as some Euro companies on finding causes and solutions to many of the issues plaguing todays GDI powered vehicles, and many would NOT have made the transition from port injection to GDI if not forced to meet CAFE fuel standards and ever increasing emissions limits.
To date, we have solved several issues and determined causes from the GM 2.0T L4 engines high piston failure rate to the Ford Ecoboost shudder and misfire issues as well as current solution implemented in every GM 3.0 and 3.6L V6 GDI engines from late 2013 to present. I have no "selling" to do, I am sharing a lifetime of working in the industry from the side many never glimpse much less understand (look at GM's ignition switch debacle costing several hundred million $ and Fords 6.0 diesel
The OP asked the question, and I gave a very cost effective answer that is documented over and over and provide the technical details as well and have tons more if you care to learn and want to see more. But I came in here being polite and following forum rules, and to jump in with insults and false claims is uncalled for. Members come to these forums to learn, and all should be able to treat others with the same respect they would expect in return.
I am more than happy to discuss all of this in as great of detail as you wish, and be technical and civil, but there is no need to be rude and insulting and I won't play that game. Ask me anything technical.
Cheers,
GDI Tech
To try and offset the mpg loss of adding more aggressive tires....
I have not seen a 1-3 MPG increase but I do have a lovely loud hissing noise and I smell oil from my catch can. Even if its working, paying for something that does that is really irritating me.
something aint right. i dont have any hiss and no smell.
Become aware of your driving habits and select the fuel mileage monitoring screen in the DIC. Being a bit less heavy on the throttle helps. Also Google hypermiling, and a few may peak your interest. For example apply your brakes as if they were completely worn out. This causes you to slow down sooner resulting in more coasting.
