x-mas truck gifts post em up
Gift certificate for window tint....now have to figure out what percent tint to get.
Im running 20% 3M and is a perfect match in darkness to the rears imo
  • Replies 46
Got a CAI and the rectangular chrome running boards hopefully have it all on by sunday
My certificate is for a full tint (including rears). I think I'd like to do the front around 20, but would like to darken up the rears a bit more than the factory. Was thinking maybe a 30-35 over the factory in the back might be good, but still do looking.
I bought her some 4.56 Gears , and getting a bedcover this weekend 47c6b98501f0d487404012d672994071.jpg
clint... the more I see your truck the more I want to lift mine... keep me posted on the gear swap..
I had mine tinted with 20 on the fronts, 35 on the rear door windows and back glass and it looks just slightly darker on the rear windows. I had the front windshield tinted with an 8 inch 5% eyebrow.
thanks buddy, I say go for it, you only live once, and the gear swap is awesome, I finally have 6th gear now, 70MPH 6th gear at 2,000RPM, best mod by far
Any chance you could post up a pic?
I will post one tomorrow as soon as I take it.
Like to see someone wrench on their own truck. Especially one that looks like yours, new and a lot of money in it. Most get dropped off at a shop.
Isn't your truck lowered?
I went 20% front and 35% on back windows and I love it. I have the 3M ceramic.
Before
After
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
