3 minutes ago, RDKILL said:
Sorry to inform you, but your hypothetical analysis is incorrect.
My truck is tuned to run a 50/50 mix, and if I choose to, I can run 100% 93oct and not have any problems...I just can't run 100% E85.
I run 93 only during the cold winter months without a problem, so no biggie other than loss of performance if there's no E85 available.
This is factual and true data.
Have you run 100% 93 yet?
9 hours ago, KARNUT said:
I don’t understand your response. My GMC was E-85, ran well on all gas. The best on E-85. If I was going to run an engine tune I would run a E-85 tune. Running a tune for a mix of 93 gas mixed with E -85 would be a lesser tune for lower octane versus an E-85 tune. With the sensor you would get more hp out of E-85. You still could run other grades with self adjustment.
Now this may be the difference between a tune and a sensor.
I think with a sensor I would be able to run 100% E85 if I wanted to...just need to confirm if I would be able to do 93 also, which I can't see why not, but better to verify first.
I could use an additional 25 ponies.
LOL!
You need to read my post a little closer...I run 93 only in the cold winter months, so yes I have with no problems.
I have a 2015 Silverado LT 4x4 Double Cab 5.3 with RPO code FH0 (Not Flex Fuel).  I have been running E85 in my truck for the last 4 tanks with absolutely ZERO problems.  No check engine light, no stuttering, no hesitations, no misfires on cold starts.  I am beginning to believe this $100 option is for a yellow gas cap?  It wouldn't surprise me a bit, and I'm going to continue to run E85 till winter hits.  I can definitely tell those extra 25 ponies are behind the wheel!!!!!!!
The only problem you might run into is a lean code if you run 100% all the time and really get on the throttle.  The ECU does not accommodate for the ethanol in the system since it can't detect it and so will not change you fuel map to do so.  The kit is well worth it  and the tune will really wake up the truck. To me it is well worth the cost and I'm going to convert our 16 Suburban over to E85.
Not to mention E85 here is $2.16 a gallon and premium is $3.26.  So even with the lower mpg I get I'm still ahead on miles per gallon cost.
So far so good. My mpg has minimally suffered, but in return I have lots more power.  All I’m saying is, the now $300 conversion (instead of the $100 option) might not be necessary. I will return to running 87 during the cold months.
What did you do?
Did you get an E85 tune and/or a sensor, or just a tune?
On another note:
I did the CRC GDI intake valve cleaner and boy what a difference it made!
11 minutes ago, RDKILL said:
What did you do?
On another note:
You have to have a sensor to get the full benefits of running E85.  Otherwise the ECU has no way of knowing what fuel you are running to make changes to the fuel map.
Thank you, I realize that is the case, but was just wondering what nkoenig did being that he mentioned the kit may not be needed.
I have seen performance increase with just a tune, but I am thinking of getting in touch with CJ to explore the kit.
BBP has told me that would be the best way to take full advantage of the fuel...just like if I added headers, cam, supercharger etc.
He didnt do anything but put e85 fuel in his tank
On 4/12/2016 at 9:07 AM, bobbobtar said:
Seat of the pants, I could tell it was different, felt like it had better acceleration.
Better acceleration, better tranny shifting, no black soot on or in tailpipe.
And a moonshine smell whipe running all make up for the mpg loss! :thumbs:
9 hours ago, RDKILL said:
What did you do?
On another note:
I didn’t get an e85 tune. Everything is still the way it came from the factory.
Looking under my truck just forward of the fuel tank, I see two metal fuel tubes coming/going to the fuel tank.
I'm not sure which tube is going in and which is going out.
Does anyone know for sure which tube the sensor would be grafted/installed to?
I see the wire harness is tied up near the tubing, so I'm assuming this is the area the sensor would be installed, just not sure which tube...hate to cut the wrong one!
I see in the pcm that mine auto detects for the sensor. I can change the tune in there. It is sad that the fuel line to the engine is so much work to replace. A splice in sensor is easier but cost much more and not for the average Joe as a DIY.
I will look into the software but so far I don't see or believe the MPG changes based on alcohol sensor. Meaning it takes much more E85 to run then gasoline. So how is it calculating this?
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
