Stress vs income
darkfox1
With a second child and additional expenses the finances are a little tighter but I am getting a raise in a week that will be backdated to January when my annual review was due, it won't make a world of a difference but it will surely help. We've been stressing a bit lately since the medical expenses since janury along with the differential rebuild put a dent in the savings.
And I am also in the process of getting promoted this summer which will hopefully be a significant raise along with a bump in the profit sharing tiers. I'm 27 and have a bachelor's in business/communications from ASU, I can thank my family for raising me as best as they could and sacrificing a lot to get me through college. All I know is that my stresses never compare to what they have experienced.
  • Replies 34
So......I've been off work now for 17 days. I'velost 11 pounds, gained two notches on my belt, blood pressure down from average 137/85 to about 122/70.
On the other hand, my back is killing me from helping my fiance "gardening", (meaning taking out a bunch of shrubs and small trees), the cats are driving me crazy, all I seem to do is run errands for her, and listen to complaints, we only have basic cable here so there's nothing good on the telly during the day, and I have to do the laundry.
So think twice before you abandon a suck-ass job. You might live longer, but do you really want to?
That's funny. Humor may not pay the bills, but it is better than stress.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
