Tested Valence MPG Before/After
Just as it says, wanted to take it off and see the impact while I was at it. Picked a route, all highway, never below 60 mph or above 70 just sticking at the speed limits with cruise control. Ran back to back with in an hour, this was between 11 pm and midnight, light traffic and didn't impact the test speeds. Route was 40 miles with a u-turn to change direction. Started once I got to 70 mph speed limit and set cruise unimpeeded (reset trip mpg then too), dropped to 65 shortly there after (the speed limit and cruise) and kept that until the bridge where I dropped to 60 and kept it until shortly there after made the u-turn. Gently accelerated back to 60 and set cruise where I continued to adjust it according to the speed limit and back tracked.
Before mpg with the valence was 23.3, after it was 22.1. Noticed it not going in to 4 cylinder mode as often with it removed.
I never thought it would have that much impact, thought maybe half an mpg at highway speeds. I did hear an engineer state it was 1 mpg that the valence gained them on the Colorado / Canyon but thought that was a little far fetched.
Either way I knew I didn't want it stock on there, removed looks good but unfinished so I always wanted to trim it which I will be doing. Like the more finished look and hope to get half that difference back.
I know there will be some who say it is a truck who cares, well truth be told it is a big thing to many shoppers and it they can save a little fuel who not? Why anyone would just want to piss money away is beyond me, I will save anything I can get because that is how I operate (not that it will make a difference to me).
Truck is a 2014 CC 5.3 4wd Silverado with the 3.42 rear end and 8k miles on it, all stock including tires and added a tonneau cover and bug deflector. No AC on during the test, just the fan, windows up, temp was upper 60's. All tires were around 37 psi during both tests. This was in the DFW area so pretty flat other than a small incline or bridge. Truck didn't down shift at all and on some of the hills with the valence it kept 4 cylinder mode engaged, without valence not so much.
Hope that helps, this isn't scientific but it is a pretty good indicator. Designers spend tons of money on design and testing so it sure had to account for something. Those have have removed it and say it did nothing probably don't drive highway much. If you do a lot of city driving and see an overall average you won't see much a difference. On a ton of highway miles or a road trip you will be able to see it.
That and 4 cylinder mode does make a difference, easily visable the mpg difference each time it goes in and out (which is probably why the mpg dropped, less 4 cylinder mode because more of the truck was in the air holding it back and needing V8 to keep speed).
That is my 2 cents and unscientific test, discuss...
Tyler
  • Replies 41
"valance"
Our truck's valance was cued from the Vettes, engineers already confirmed it lowers aero drag. They pointed out the outsides hanging lower for the tires, and center being a bit higher made the biggest difference. In the same video it also showed a 2nd valance under body panel (prototype valance/panel) frame mounted I believe its transmission mount section. I guess it never made it to production.
Since your own findings prove it works why would you remove it? I guess if your going to trim you're valance, keep the same GM design and just shorten it in ratio.
I know you tried your best to keep both runs as close as possible, but the difference of 23.3 and 22.1 is 1.2 mpg. Which is about 5% difference. That 5% difference could have been attributed to a pick up in wind, or slightly different acceleration. I would have to see more thorough testing to support a claim that the valence improves mileage.
I'd say about 5 runs with the valence and 5 runs without the valence, and then average each side out. Then compare.
Neat experiment tho.
Tyler's test may not be 100% controlled but it does support keeping the valance attached to your truck. I believe like many others that a truck looks better without it. I also believe gm puts it there for a purpose and if it saves me money, it looks better to me!. A saving of only a fraction of a mile per gallon makes it worthwhile in my opinion.
I didn't really buy my truck to get good gas mileage. There are far more options for that. But I agree that every little bit helps, I believe if you like the valance, leave it, if you don't like the looks of it, take it off. It is your truck. :-)
mines been ripped off since day one. at 70 with no wind i get 21-22 and thats leveled 2 inches with no v4
Took mine off this weekend. Had it off on my previous truck as well. I think it looks better without but to each his own. If it makes a difference in mpg its so minor that it doesn't matter to me.
I keep a spread sheet of my mpg's from every fill up for my truck. I went the first year with the air dam on and have had it off now for 7 months. When I get a year with it off I will let you guys know how it turned out. The mpg's lost will vary for different people due to the average speeds in which they drive, the faster you go the more drag and the more fuel you will save with the air dam on compared to with it off. I figured one year with it on and one year with it off will give a good idea but I rarely drive on the interstate so my results will be different than others.
That is about the same mileage I think I lost when leveling the truck so while it may not be a huge amount of controlled variable runs, I'd say it is pretty accurate given how much you were able to control the variables. Thanks. At 1 mpg average, for me it amounts to about $175 per year in additional gas expense.
I agree and let us know but couldn't you comply 7 months for now and see a difference or not?
Sent from my SM-N900V using Tapatalk
The first year will be during the break in period. Maybe take similar periods following break in to try and keep the variables to a minimum.
Be interesting to see.
I took mine off after lifting/leveling it w/ bilstein 5100's & adding 1" more block to the rear.
#1 - GM trucks are the lowest 1/2 tons on the market from the factory, and this relatively huge chin spoiler/valance whatever you wanna call it clearly amplifies the already low ride height of the truck.
#2 - If you're looking for some added rationale for removing the ugly thing, most people get a tonneau cover for their trucks, I believe a solid/semi-solid tonneau cover would offset the fuel mileage loss from removing the valance.
#3 - My now 11,000 mile 2015 6.2 8 speed CC 4x4 short bed that has the level & valence removed is averaging .3 mpg BETTER than my now totaled w/ 40,000 miles '14 5.3 CC 4x4 std bed truck that was NOT leveled and had the valence on. Both trucks got 93 octane. My driving habits remain the same - 16.1 for the 6.2 leveled no valence and 15.8 for the 5.3 stock - more rationalization for ya.
Actually a tonnaeu cover does not improve fuel mileage.
That is anomaly...
Actually it does, how much is up for discussion but independent tests as well as manufacturers have shown otherwise.
Thanks for the correction on Valance, since there are two spellings auto correct didn't catch which one.
I will try to remember to do another test (though it will be different weather) after I trim it.
Remember this is strictly highway, no city. If you run averages with any city mixed in the difference will be less pronounced, much less depending on the amount of city driving/idling.
The reason I would remove are a few reasons. One because this truck leaves the pavement and it is a hindrance, two it looks better and three it has already been scratched up a few times around the city and I don't want this to break and have it rip out the center "skid plate imitation design thing" piece at the bottom of the bumper that it is attached two. It was 16 bolts and clips to remove, if it gets ripped out other pieces very well might come with it.
Doing multiple runs to average no doubt would have been best but I wasn't investing that much time in to this. I think just over 5% is a little out of the error range but it certainly could be much closer. Weather shouldn't have changed much as storm were long past and it was fairly calm.
Some good ideas out there fellas.
Tyler
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
