So I haven’t had time to check for an exhaust leak. I drove to Detroit last week, 400km round trip. As usual, on the highway, no issue, but the marble noise at low speed under load.
I typically run 87 octane, so when I got back I filled up, but with 91 instead. Tank was half full.
what have I noticed? The marble noise has eased back and while present, is not half as bad.
This put me thinking. I basically now am running 89 octane. But probably have been running poor fuel leading to a knock issue.
this thread below sounds similar to what is going on with the majority of these trucks.
I’m still going to search for an exhaust leak next weekend, but I’m thinking this could be a knock sensor issue, that’s retarding a spark long enough, but not severe enough to trigger a CEL.
I've run a few tanks of premium and mid grade, and have noticed no difference.  Also did a Sea Foam flush in the intake and the tank.  No difference.
I don't believe it to be fuel detonation related.
My sound has been as bad as ever lately (even with the Sea foam and higher octane fuel).  While towing my boat, it sounds like the engine is going to rattle through the hood.  Loud enough for my oblivious wife to actually hear it.  I was towing last weekend and had to make a hard stop.  When I pulled away the sound had disappeared.  Sounded like a normal truck for the rest of the drive home.  I've also noticed that I can't heard the sound while accelerating during a turn, but when I straighten out it comes back.
I can't see how an intermittent sound can be caused by low  octane fuel.  Maybe the sound is always there, and I only hear it when something settles into place in the driveline and causes some harmonic vibration.  Either way, it's very irritating.  Might be time for some Dynamat all over the floor and firewall.
Anyone know how to get some actual GM people to look at these threads?  I've seen them pop in on other forums and offer to "help".  This seems like a big enough issue for them to be paying attention to.
Been a while since I chimed in, mine has become more consistent, it is just about daily now. 400 mile road trip this weekend and listened to the tick the entire time, even my passenger in the front seat commented on it. Just hit 1 year of ownership with 12k miles
Yep, mine goes away around corners (Especially long on ramps). It can be made to disappear under hard acceleration in 1-2 gears (when I assume torque moves the engine the most). Hard stops cause it to be gone and return on a bump that moves the truck around a lot.
I have been to busy to get it into the shop but my Power Train warranty will be up soon so I am going to try and shoot for an appointment next week. Haven't had time to try any other diagnostics myself.
Truck sounds fantastic when it isn't ticking. I notice the GM reps are staying away from this thread.....Wonder why....
The last few posts here are spot on with what I hear. My dealer said couldn't duplicate and is normal. I can put up with a lot but a loud ticking noise isn't something I feel I can live with. If I don't resolve this soon i will be moving to a ford or 2012-2013 chevy if I can find one.
Sounds like a firewall steering boot failure!!
My steering boot and connection to the firewall has been covered with sound deadener since May.  Noise still there.  It isn't that.
Ticking drives me insane.  I told my wife I was gonna do the same, basically trade in my truck for an old beater.  She said "you have a beater now".  At least the interior of my current truck is nice.  Maybe some knobby tires will drown out some of the god awful engine sounds it makes.
There's times I think I'm driving an old Singer sowing machine
2 hours ago, Spastik Monkey said:
I think GM doesn't want to get involved as I'm guessing they know the cause. I'd imagine the fix is probably expensive.
Maybe the fix is cheap....... it is the volume of repairs and dealer reimbursements that keeps them from chiming in.
That's more or less what I meant. Overall cost of all the units needing repair.
1 hour ago, AdamGMC2017 said:
If there is a fix, I wish they'd let us know.  I'll pay for it myself.
Absolutely not. This needs to be addressed and covered under warranty
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
