Many of you might already know this, but here are the updates for 2017:
New Features
  • (GPA) Graphite Metallic
  • (GMU) Pepperdust Metallic
  • Capless fuel fill
  • (TDM) Teen Driver mode
  • (UHY) Low Speed Forward Automatic Braking is added to the (Y86) Enhanced Driver Alert Package
  • New Inter trim (HQZ) Jet Black Medium Ash Gray available on 3LZ
  • (RKX) P265/65R18 all-season blackwall tire
Changes
  • (IO5) and (IO6) audio systems now include Android Auto
  • (KB6) heated and vented seats change RPO code to (KQV)
  • (GAJ) high Country now includes; (Y86) Enhanced Driver Alert Package, (TQ5) IntelliBeam headlights, (JF4) power adjustable pedals and (UVD) heated leather-wrapped steering wheel
  • (UVC) Rear vision camera is standard on LT trim and removed from (PCM) LT Convenience Package, (PDA) Texas Edition and All Star Edition
  • Capped fuel fill is included with (ZW9) pickup box delete
http://www.gmfleetorderguide.com/NASApp/domestic/newfeatures.jsp?year=2017&regionID=1&lang=1&divisionID=1&vehicleID=20064
  • Replies 37
Android Auto is already standard, it was standard in the GMC starting Feb 2016. I guess they wanted to make it look like they added more for the 2017. lol
Not a fan of the capless fuel fill. I know F*rd has been doing this for a whille....maybe that's why.
It was a software update on early 2016 trucks. Plus, they stripped the Car Play radio for a month.
Thanks for the info. Glad there is nothing to cause buyers remorse for those w 16s. I do like a black w gray interior option. May have chosen that.
Finally .... I can keep my 2016 for at least 1 more year. I see nothing here I don't have already except the fuel cap... I can deal with that one.
My explorer has capless fill. It's fine until you want to use a gas can to put fuel in. Then you need there special little funnel. I'd rather just have a cap. Wouldn't want to pay more for a truck to have it. Same with push start. Seems there just trying to add stuff to make people think things are improving for the price.
I bought an aftermarket cap for my '98 not long after buying it used that made it like a capeless fill and it through a code saying the system wasn't sealed good enough. Same as if you put an aftermarket locking cap since they seem to through the same code. I think I feel better about an actual cap doing a better job sealing the system.
Not to mention with capped there is still a flapper in the opening and I think an anti siphon valve.
Not to side track this thread but once you have keyless entry and start you really miss it. I constantly grab the door handle on my Silverado expecting it to open. I hate digging into my pocket for keys now.
This is my only veh without keyless features.
Ya because it's so hard and takes so much time to get your keys out of your pocket and put an actual key in the ignition. Plus I've heard of times where a passenger was the one with the keys and they got dropped off or something and the driver just drove off with no problem without the keys.
I've heard of times when people liked winding there Windows up so much the retro fitted cranks. Not really, but Like I said once you have it you realize how much it stinks to not have it.
Really not about difficulty but becomes a needless exercise and seems to occur the when the hands are full. I'm sure I can survive just find myself forgetting a lot
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
