HSA
silveradosid
after reading the manual about hill start assist, I have discovered mine doesn't work. my driveway is about a 4 degree incline, when I pull into the driveway and want to inch my way in HSA will display on dic but the truck will keep rolling backwards unless I give it gas. then the truck will lurch forward and I have to hit the brake. if I let off the brake I get the same thing with HSA and the truck rolls backwards. do you think this is a transmission problem.
HSA is not at all connected to the transmission. HSA just applies the brakes and will only do so for about two seconds according to the manual. Are you rolling backward instantly or does it take a moment for it to start?
Also, HSA will only engage once per stop. So if you're crawling in a stop and go sort of fashion, it will not engage every time.
You'll also notice it's working if you let of the brake, and instead of hitting the gas, press the brake pedal again. You'll notice a much firmer pedal akin to when you pump the brake pedal when the truck is off.
Health Savings Account comes to mind.
Sent from my SM-G930V using Tapatalk
It only holds for a couple of seconds as someone stated earlier. It is designed to hold the truck as you transition from the brake pedal to the gas pedal so the truck doesn't roll backwards during the transition.
Have to make sure you come to a complete stop before letting off the brake.
I've also been wondering if leveling/lift kits adjust how the truck determines its angle. Since they come stock with 3-4" of rake, being on a 4 degree incline might make it think it's close to level. Stock rake might make the truck think it's going downhill all the time, which is why people complain about grade braking...
Anyway, wish I had tested with it stock height. But every incline I come to, I come to a complete stop. The truck will stay stopped until I press on the gas. It has never released on its own before, and I've waited for 60+ seconds due to traffic.
The message pops up on the DIC for a few seconds before going away.
i do have 1.5 lift in front, i tried again last night. i pulled in my driveway and used the brake to bring the truck to a complete stop and when i let my foot off the brake pedal the truck will start rolling back out the driveway.
I believe you have to pump the brake 2 or 3 times for it to enact the HSA program.
Nope.
That's extremely odd, especially if it's popping up on the DIC telling you that it's active. Maybe try to find a taller incline, experiment around? If not, perhaps resetting the computer (disconnecting the battery for 30 minutes or so) will help. Can't hurt to try. Let us know if you find anything else out!
During the transition period between when you release the brake pedal and start to accelerate to drive off on a grade, HSA holds the braking pressure for a maximum of two seconds to ensure that there is no rolling.
The brakes will automatically release when the accelerator pedal is applied within the two-second window.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
