Duratrac tire pressure?
Knightfall
Just got new P275/60/20 and I'm curious as to what pressure you guys recommend running; the place I got them at set the pressure at 37 psi. Goodyear's website listed a max pressure at 51 psi and I like running higher pressure to save on gas, so I'm thinking maybe upping that to around 40 or so psi. Opinions?
My truck came with duratracs and they were set to 38. I run them right at 40, the DIC shows between 39 and 40 all the time on them.
32 or 33
I used to run lower pressures like that, but it just makes the tires (especially the fronts or the rears when you haul or tow) look low on air. I honestly wouldn't run lower than 35 or even no lower than the high 30s on a full size truck unless you're driving off-road or in the snow or ice. But, only pavement (dry or wet) I wouldn't go below 35. I know lower the pressure the better grip and rides better, but it just makes tires look low on a truck. At around 32 it almost looks like the outer sidewall was acting as part of the tread on the contact patch, especially hitting bumps.
275/70/18 E-Rated : I inflate to 40psi(cold) which translates into approx 44psi(hot). I carry a considerable amount of weight full time. I've run this pressure for the last 20,xxx miles with even wear. Noise has definitely increased. I definitely prefer the higher PSI , truck handles better. At the lower psi the front tires/steering feels "squishy". I run 30psi(cold) which translates to 34psi (hot) on weekends , since I'm on/off the beach multiple times a day and don't like the driving characteristics as much. Great tire all around though, super happy with mine.
mine are set at 40 - 45 psi. - 265 /65 / 18 . tires get rotate with oil change
  • 3 weeks later...
  • 1 month later...
While the idea of running higher pressures to save gas seems logical due to less tire flex, it can have the reverse affect. Too "hard" of a tire can cause some "wheel hop" on bumpy roads and lead to increased micro managing by the traction control electronics and actually cause decreased fuel economy. And then there is decreased safety in terms of reduction in braking effectiveness and such. Tires are designed to work in compliment with suspension to absorb road shock. By stiffening up the tire, more of it is transmitted to suspension components that can lead to increased wear on them. Too high of tire pressure for the loading will cause less actual tread surface on the road and affect handling and safety. Too bad that the tire folks don't supply loading/pressure charts for auto/pickup tires like the do for their commercial heavy truck tire offerings.
Even on E rated tires on my 2015 2500, I typically only run about 50-55 psi in them when empty or light loaded as opposed to the 60 front 70 rear OEM recommended inflation. Their inflation recommendation is for a maxed out gross vehicle weight. By running the lower pressures when empty, I get much better handling, a improved ride, very good tire wear, and a slight up tick in fuel economy. 2500 6.0L are gas hogs right out of the gate, but I have pulled off an average 14 mpg for the lifetime of the pickup and usually 17-18 mpg on road trips. Almost into 1500 mpg territory. Only 1 mpg less than my previous 1500 averages.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
