Small mod
Sean3565
I checked off a small mod today off of my list of things that I want to do to my truck. Since I carry my keys in my pocket all day I added a jacket to my key fob. I have used these things in the past and they really do protect your fob from scratches. They also help prevent accidentally pressing a button on your fob when bending over with keys in you front pocket. I normally remove my shoes in the garage before entering the house, on more than one occasion while getting ready to leave for work and bending over to put my shoes on in the garage I have managed to sound the horn via the panic button. That usually gets me awake! Here is the before and after.
That's actually not a bad idea......where did you find those fob condoms?
I just did the same thing yesterday. I ordered THIS one. It covers the fob completely. Works great.
I've had the same one sitting in my saved items for a few weeks now
Grab it. For the price, you won't be disapointed.
I have this and I love it. I bought mine from Amazon. They have multiple colors. Mine was about $8. Highly recommend.
Sent from my Nexus 5X using Tapatalk
Which do you have?
Which do you have?
The one I have is the open one that doesn't cover the buttons. I'm sure either would work well.
Ok - I'll probably try the "full coverage" option because I don't want a bowtie on my GMC fob!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
