Next Mod: OEM Ram air Hood
EXSlider400
I've seen that one, not really a fan.
I am still kind of torn on it. I do like the OEM looks on the Rams both 1500 and 2500.
And where exactly does it "ram air" into? An engine bay? This looks like a waste of money unless you get a reworked intake tube that matches up to the hood that would actually force air into the intake. This is like gluing stacks to your cab while running your regular single exhaust.
Ram air directs air towards the intake already with channels in the hood. You can check the links above if curious.
Is this effective .. not a bunch, not like it will make a notifible difference as these K2s are not starved for air. It is 99.9% for looks and does look nice.
This looks fine and is purely decorative. The massive front grill of the GMC pretty much eliminates any potential need for an additional hood vent. I would be happy if my truck came with this design feature, but not something I would add as a modification.
Looks really nice. As far as it being a waste of money, arguably all mods are a waste of money, or at the very least a "want" versus a "need." I dig the look of that hood!
Yup Yup Yup, Fully agree.
Personally I like that Phat-ass Duramax badge on that better than the schoop but both are nice. All I need now is about 100k worth of toys to pull to warrant getting one LOL!
Don't we all, brotha
Love the looks of that! Has anyone seen a Putco or something like Putco where u don't have to replace whole hood? Pure decoration!
Not a 100% accurate, Ram air works very well. GM used it on the 4th gen F-body's with great success, it has been used on motorcycles for at least 20 years now. It was worth a 10hp bump on those cars over the non-ram air models. Our Audi uses ram air from the factory as well. It wouldn't take much to fabricate an airbox extension to route the air back over to the air box. Now we are not talking any type of huge PSI increase in the airbox, but a 1psi increase has been seen in some models.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
