Hello,
I wanted to share my A10 - Inside RearView Mirror conversion from UE8 (OnStar Only) to OnStar and Auto Dimming (UE8 & DD8). I have read a few threads out there from those that have attempted this by tapping into nearby power circuits. I didn't want to go this route and wanted this to be a Factory as possible. Also, since I completed the Side Mirrors Conversion (DL8 to DL3), I also wanted have the Auto Dimming feature working on the Driver's Side Mirror as well. After completing the conversion, I can confirm that I now have FULL functionality with Auto Dim on the Rear View Mirror AND my Driver's Side Mirror
This setup is for my:
2016 Silverado, Crew Cab, LT, 5.3L Gas.
Your mileage might vary. Please confirm wiring for you vehicle!
NOTE: Having the Driver's Side Auto Dim function to work, you MUST have the circuits in the Driver's Door Panel harness. Since I converted by harness from DL8 to DL3, I had the circuits already there.
I created a PDF of all my notes and research to ensure I was doing this right and like it would have come from the factory. Please see "A10 Mirror Connector Reference". I hope this helps those that also want to this. I used pre-terminated terminal leads that I bought from eBay. Those part #s are also in the Reference Diagram.
There are a total of (4) Circuits Needed that were missing in the A10 - (UE8) Mirror Connector. To get the DD8 Option you'll need the following circuits (please note, these are also listed in detail in the "A10 Mirror Connector Reference). I advise to print it out to have for easy reference and understanding.
Circuit 24 - Backup Lamp Control (Light Green/Red Stripe)
Circuit 1690 - Automatic Day/Night Mirror Signal (Yellow/White Stripe)
Circuit 1691 - Automatic Day/Night Mirror Low Reference (Black/Yellow Stripe)
Circuit 1739 - Run/Crank Ignition 1 Voltage (Violet/Light Green Stripe)
UPDATE: When i did this upgrade back in September 2016, the instructions in the cross reference sheet I provided include sourcing the Pre-Terminated Leads from GM. Since then, I have found the actual terminal pins so that you can crimp then yourself. They are cheaper in price but will require a crimp tool.
Pre-Terminated Leads:
A10 Mirror: 13575867 - These sell for about $6 each. You'll need (4) = $24
X51L/X61A Panels - 19301767 - These sell for about $14 each. You'll need (4) = $56
Total Cost = $80 for Pre-Terminated Leads + Shipping
Terminal Pins from Mouser:
A10 Mirror: SAIT-A03T-M064 - $0.07/each - You'll need (4) = $0.28
http://www.mouser.com/ProductDetail/Delphi-Connection-Systems/13849930-L/?qs=sGAEpiMZZMs7eK6h2EBtKnVYD9xPrV6CnMqjFL3PycU%3D
X51L/X61A Panels: 13849929-L - $0.18/each - You'll need (4) = $0.72
http://www.mouser.com/ProductDetail/JST/SAIT-A03T-M064/?qs=%2Fha2pyFaduhkh82d7cDA4KZPGw2IAWOBN4IAbsI5FZ%2FIEBdeeFjRSg%3D%3D
Engineering Inc. PA-20 Crimp Tool - $35 on Amazon
https://www.amazon.com/dp/B002AVVO7U/ref=sr_ph_1?ie=UTF8&qid=1487961421&sr=sr-1&keywords=pa-20
Total Cost - $36.00 for the Terminal Pins and a Crimp Tool + Shipping
So, you will still save $40 getting the pins, crimp tool, and crimping them yourself. Since the pins are very cheap, I would pickup a few extras for crimping practice.
Step 1: I took a High Quality - 25' HDMI Cable and stripped wires away from it. I wanted to get the wires to be as close as to the GM color code scheme as possible. These wires were 22AWG.
Step 2: I grabbed the four wires closest to the color code scheme and wrapped them with automotive harness tape.
Step 3: I removed the Overhead Console and began running wires along the headliner (inserting from the front edge gap and working my way to the A-Pillar of the driver's side. At this point, I removed the fuse panel cover on the driver's side door to expose the X51L Fuse Block Instrument Panel. The purple wire will land on Pin #13 of the X3 Connector (this is on the right side of the Fuse Panel).
Step 4: I separated my harness so that my purple wire (Circuit 1739) landed inside the X51L Fuse Block Instrument Panel with the other 3 wires (Black, Green, Yellow) continuing down the side into the footwell area.
Step 5: Since I have the Kicker VSS System, I had to remove the amp as it sits on top of the X61A Junction Block. Remove the top cover to expose the connectors. The connector you'll want to remove and look at is the X3 Blue Connector (top left corner). This is where the 3 circuits will land. Pins #8, #9, and #13 is what you want. It was a real PAIN to insert since there was not enough slack in the harness, so be prepared for awkward contortion. :) NOTE: I did completely pull the fuse block out and verify pins on both sides of the fuse block. That is also noted in the reference diagram. Inserted leads, wrapped excess wires with automotive harness tape, zip tied to existing harnesses, connecting everything back.
Step 6: In the overhead console side, I landed the terminal leads into Pins #1, #2, #8, and #9 (Also referenced in the diagram).
Put everything back together, took a test drive at night... ALL IS WORKING!
Hope this helps, let me know if you need any help with this.
Here is the PDF I created for the complete wiring diagram and photos.
A10 Mirror Connector Reference Here! ENJOY!
https://www.dropbox.com/s/e8hnnt7nvdsv1wa/A10%20Mirror%20Connector%20Reference.pdf?dl=0
Edited by pgamboa
  • Like 4
Thanks Guys! Spent lots of time reading the Upfitter Manual to ensure I've covered all the circuits needed across all connectors to make this work. Gotta love that feeling when you put everything back and it works! I hope I can continue to contribute on mods like this.
  • Like 4
Updated Reference Diagram to include Terminal Leads for both ends of the connection points. Also, total cost for this upgrade was $136.45. $94.45 for the terminal leads and $42.00 for the mirror. Enjoy!
  • 3 months later...
Wow what a great forum. First let me thank you and everyone who has help on this topic. I don't think I would have done such a professional job without it. A special thanks to you pgamboa for all your hard work and time. My question is: Do you know the terminal end piece number . Is it 12020757 for the X51L/X61A boxes. I don't want the leads, just the terminal. Thanks
I bought this one on ebay. Said it wasn't compatible but it works it was from a lacrosse I think there is one on ebay now
E11026538
Also this # looks good GM 13584893 check it out I can not confirm this one the other one (E11026538) I know works
Edited by carnut325
I must say thanks to Phil for all the good help he is to all of us on this forum!! I just did this mod last night and let me tell you guys it works like a charm!!! all the instructions and diagrams that pgamboa provided are dead on!! Thanks Phil!!!
Thanks a awesome post getting my supplies together com on GM what in the hell is 4 extra wires in a harness fit what should be a STANDARD feature.. How many years was the pickup trucks pre wired for this
No kidding. Let me know if you have any questions. I hope you have patience with the X61A - Junction Box. :). It was a PITA to land the terminals in the connectors. Releasing any zip ties and getting as much slack out might help.
I got the terminals part #13849930 these are for the junction box terminals I hope because the way I read the post these were for the mirror plug side these terminals are too big for the mirror side plug the others are in back order hopefully they fit the mirror plug I ordered from mouser
Just picked up a mirror from eBay for $60 CAD with free shipping. Will be doing this to the truck on days off now. Your the man!
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 424 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
