Would any of you (us) consider installing one and relying on manual operation? i.e., skip the complicated wiring and just install the glass. I assume there's a way to manually open/close...
Will be doing this mod soon. We have it all figured out in my thread below. Just waiting on rest of parts to come and I'll film process.
https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fwww%2Egm-trucks%2Ecom%2Fforums%2Findex%2Ephp%3F%2Ftopic%2F201782-Rear-Sliding-Window&share_tid=201782&share_fid=33003&share_type=t
Edited by WesternSilverado
  • 2 years later...
On 10/7/2016 at 6:56 PM, Dbeto54 said:
Here is where Im at so far on the rear sliding upgrade,
Window installed
Switch and plate installed
Relays in place
Wiring might not look as clean as factory installed but once I put that cover on who is gonna know is even there. Im 95% pretty much done I just need to tap the power and ground source and I'll be all set.
Parts used
23373685 GM Rear 3pc glass $200 used plus $65 installation
23104426 Trim Plate Gray $21 new
22774498 Switch $25
ACDelco PT796 Pigtail for the switch $25
5 Pole NC/NO Relay x2 $10
So about $350 total
Hey man i have all the parts ready. Im doing this swap this weekend. Could you please tell me what are all the wires you used and where did you tap in for power and ground?
  • 7 months later...
Did you ever get this to work?? If so, how much did you spend? Got a buddy that would like to make this conversion but wants to know how much he's going to spend. Also here in Houston. Thanks!
  • 1 year later...
On 9/24/2016 at 3:21 PM, Dbeto54 said:
Yes factory wiring is already in place. I would only need to add this 2 parts and I'll be set
Did it have to be programmed after connecting to the factory wiring?
    erickn520
    erickn520
  • Who's Online   4 Members, 0 Anonymous, 1,746 Guests (See full list)
