Black emblem
Obviously ya gotta make sure the emblem to be plasti'd id clean, dry, masked off, etc. Other than that is there any other prep work needed such as sanding to "de-gloss" the surface?
Thanks
  • Replies 44
No sanding whatsoever!
Just clean and dry the surface.
The best thing about plastidip is if you don't like it you can peel it right off and have your original finish!
I plasti dipped the honeycomb section of the grille on my LT just recently. I wasn't sure what to expect out of it at first either, but after seeing the finished product I am now a big fan. I wouldn't hesitate.
Plastidip worked well for the GMC where vinyl would not have due to ridges as mentioned before. It seems to hold up incredibly well in all conditions and it super easy to apply and reapply. Watch some videos, you don't have to be meticulous about taping off, the excess plastidip peels incredibly easily off of the chrome surrounding of the badge.
I had mine painted by a local body shop for $45. I got mine color matched red
It's all about which route you like the most.
Bit I am happy with the product I received from
www.DeVriesSigns.com
Just do it right and fork over the money for the black emblems. Any enthusiast will see plasti-dip emblems and laugh... See this link for description
http://www.gm-trucks.com/forums/topic/191652-2014-silverado-black-bowtie-installswitch/
I disagree. I used the plastidip and glossifier on my wife's Colorado and you cannot tell the difference between the OEM black and the painted black. I've seen the flat black painted ones and they look bad, but if you use the gloss black finish it looks exactly like stock - for only $15 and 1 hour of labor.
^^ Lol I completely agree. I had a buddy that did plastidip and it immediately turned me off from the idea. I actually just taped mine off and sprayed it. I didn't like the look the first time I did it so I just sprayed it with carb cleaner and the black paint I put on came right off leaving it looking exactly like stock. Then I taped it off and redid it and it looks flawless. See for yourself :)
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
