2015 Denali tailgate has no remote lock
speedbump
Does anyone know if it is possible to add a locking tailgate that operates off the remote to lock/unlock the tailgate along with the doors? My Denali had a kitchen sink but no remote tailgate.
Haven't done it but it is doable. Not cheap using OE parts
As said, OEM no but aftermarket yes and it will work like OEM.
I know of a GM tech that did it but cost more than the above mentioned Pop&lock.
OK, I watched the video and followed the link to the item but nowhere does it mention a "2015". It seems that is the only one that wasn't listed. I'll have to dig deeper into that problem.
Does anyone know how this mechanism knows to lock/unlock with my FOB but not somebody else's Fob? I didn't see anything about programming the unit to identify your fob.
You want a PL8140 in the link that cbrsilv15 posted. It works for all 2014-2015 Sierras and Silverados as long as you already have the key lock in the tailgate handle.
And it ties into the wiring for your door locks which is how it knows to only open with your FOB - no programming required.
OK, that's what I want to hear. I'll go order it now. Hopefully have it in and working in less than a week depending on shipping time.
Thanks again...
Works great. One key press unlocks the drivers door, second press unlocks the other 3 doors and the tailgate. Plus I know it is locked when the truck is locked.
Thanks again...
No problem. The installation instructions are actually on that same link on the Pop-n-Lock website.
I watched one of the videos and it looked like a simple enough operation. The biggest thing with me is removing trim, covers and anything else held on with some sort of majic clips. I usually end up breaking most of them. What ever happened to screws??? :happysad:
Get a set of these:
http://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html
My link is to Harbor Freight but you can get them at just about any auto supply store or Amazon. They work great, keep you from breaking the trim, and save your fingers too!
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
