Front LED grille lights on black ops edition? Wanting to replicate
mattpest
Anyone have suggestions on how I can replicate the lights on the front grille of the Silverado Black Ops?
Open internet explorer.
Go to any website that sells led pods
Order whatever led pod you like.
Pay for and it and wait for it to ship.
Once it arrives, test functionality and install.
Profit.
I looked up those lights and they don't show an option for them on the Black Ops Edition. Tuscany does the packages and they don't list it on their site. They may have been on the prototype vehicle because adding blue lights to the grill is asking for trouble.
