Oil Pressure Question
All,
I have a '16 Sierra with a 5.3 v8. I noticed today that my oil pressure was dropping from 40 to 25-30 at idle. Then under heavy acceleration fluxuate from 40-60 psi. Since I've own the truck, ive noticed the oil pressure always stays at 40 psi.
I have 6K on the truck and am going for a oil change this Saturday. I've checked the dipstick and the oil looks good and is sitting at the right level. Any ideas?
It should stay around 40psi under normal operating conditions, but depending on the oil viscosity you are running and the age/use of the oil it will change. As the oil wears over time it will become "thinner" which will cause a lower oil pressure reading. I wouldnt worry about it too much this early as you are probably just barely getting that motor broke in. If you start seeing ALOT of fluctuation or extreme low pressure then I would get it into the dealer to get checked out.
My 5.3 2016 Silverado experienced the same pressure change at the same mileage. I had the oil and filter changed @ 6156 miles and pressure returned to previous levels. You should see a return to "normal" following the service. 6000 miles on 0w20 oil and a small oil filter causes noticeable changes in pressure late in the interval. :gmc:
Yeah my first oil change is Saturday as my oil life is at 18% so thag may explain it. I did just get done with a 200 mile drive today
40psi is normal running down the road pressure. The new motors have a weird smart oil pump you can look into, basically it really boosts the pressure with high RPM's. Very important to run 0w-20 Syn Dexos 1 approved oil and a good filter in these engines. In the Florida summer with oil that has some miles on it I normally see about upper 20's psi when idling at a light. Again, hot oil with some miles, in 100*F+ Florida summer and traffic and AC humping. You need an oil change from what it sounds like. I never let the 1st change go over 5k. Then follow the oil life meter, just make sure it's reset every change. I just did an oil change with 9% left and that came out to about 6,900 miles. Being your first change, I'm betting your motor put some wear on that oil.... get an oil change.
It has a 2 stage oil pump. Low pressure at low RPM's and higher pressure at higher RPM's. Its operating as designed.
Just a heads up and to save you a new post, the volt meter works the same way. You will notice low voltage at times, then when the system determines that the battery needs to be recharged, the voltage will jump up to about 14V.
Correct, the oil pump is a 2 stage pump. It is setup like this as high oil pressure is not needed at idle so it is part of the gas mileage savings GM is using to met the EPA requirements.
As posted on another thread by Southern_Sierra,
"Advanced Oiling System
The oiling system incorporates a new variable displacement two-stage vane-type oil pump that enables more efficient oil delivery, based on the engine’s operating conditions. Its dual-pressure control enables operation at a very efficient oil pressure at lower rpm, and then delivers higher pressure at higher engine speeds.
An oil control solenoid valve, controlled by the Engine Control Module (ECM), mounted to the oil pump provides two-stage functionality. The oil pump is mounted on the front of the engine block and driven directly by the crankshaft sprocket. The pump rotor and vanes rotate and draw oil from the oil pan sump through a pick-up screen and pipe. The oil is pressurized as it passes through the pump and is sent through the engine block lower oil gallery.
Pressurized oil is directed through the engine block lower oil gallery to the full-flow oil filter and then to the upper main oil galleries and the valve lifter oil manifold assembly.
An oil passage at camshaft bearing location permits oil flow into the center of the camshaft. Oil enters the camshaft, exiting at the front and into the camshaft position (CMP) actuator solenoid valve. The CMP valve spool position is controlled by the ECM and CMP magnet. When commanded by the ECM, the CMP magnet repositions the CMP actuator solenoid valve spool directing pressurized oil into the CMP actuator to control valve timing.
dexos 1™ Engine Oil
TIP: Failure to use the recommended engine oil and correct viscosity or its equivalent can result in engine damage not covered by the vehicle warranty.
The dexos1 specification was uniquely designed to complement the exacting requirements of GM’s advanced engine technology. The specification has gone through an extensive developmental and testing process. Only those oils displaying the dexos1 trademark and a registered trademark logo on the front label of the container meet the demanding performance requirements and stringent quality standards set forth in the dexos1 specification.
SAE 5W-30 is the required viscosity grade for the 4.3L engine.
SAE 0W-20 is the required viscosity grade for the 5.3L and 6.2L engines.
DO NOT use other viscosity grade oils such as SAE 10W-30, 10W-40, or 20W-50.
The engine oil with filter capacity has increased significantly from model year 2013 to model year 2014.
This also includes 2017 models as nothing has changed."
So the ECM controls the oil pressure and this is why you see it fluctuating so much. Nothing to worry about. The general rule of thumb has always been as long as you have 10psi of pressure for every 1,000 rpm. On a cold morning I have seen my oil pressure go up to 70psi.
Some years ago Ford changed their dash oil pressure gauge to not move because too many
uneducated owners complained that their gauge dropped "too low" at idle (in the 10 - 15 PSI range)
which was perfectly normal as Black02Silverdo explained. To alleviate these frivolous complaints Ford
made their oil pressure gauge needle almost stationary near the half-way mark.
Dodge had a similar "fix" for diesel owners that questioned the oil pressure fluctuating...more or less it was turned into a glorified idiot light (read 40 psi if it sensed oil pressure, read zero if it sensed no oil pressure). The later trucks had a oil pressure switch, that fed the ECM with a presence/absence of oil pressure, the ECM then made the gauge move based on engine parameters (RPM, load, etc.).
As far as I know, Dodge oil pressure is still based of a switch and ECM inputs, there is nothing that relates actual oil pressure to the reading on the gauge.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
