Price check - 2017 Chevy 2500 LT Crew 6.0
Hey Everybody,
I'm Looking at a new Chevy 3/4 ton and I wanted to get an idea what everyone else is paying/seeing for prices.
2017 Chevy 2500HD LT crew cab Z71
6.0 Vortec
All star pkg.
LT plus pkg.
Snow Plow Prep
Spray in bed liner
20" 5-spoke wheels
Asking price $53,000
Selling price $45,000
Does this sound like a reasonable offer?
Many thanks,
Jim
Hey Everybody,
6.0 Vortec
All star pkg.
LT plus pkg.
Snow Plow Prep
Spray in bed liner
20" 5-spoke wheels
Many thanks,
Jim
Think that's a little much.
Sent from my SM-G930P using Tapatalk
15% off MSRP seems to an average from my experience and want I've read here. But since it's a new 2017, I'm surprised you're getting that so early after their release (even though the gassers are the same). I'd be looking for leftover '16s if you want the better price.
Did a quick build and price on the website and got $52,325.00 after a 500.00 discount along with package combination discounts.
Agreed that you could probably do better with a 16 off the lot - there is nothing different between the 16 and 17 in terms of engine or transmission.
for 17 you may want to look at the Alaskan special edition as it does have several options you are looking for along with black wheels and special tires
Prob won't help, but for what it's worth...my 2015 new sticker was $50,000 (6.0, LT, no snow prep pkg, 4.10 rearend, trailer tow pkg, Z71 pkg) and with rebates or whatever, got it for $43,000. I wouldn't think much would change in 2 years. Same truck.
Sounds right on to me. Looks to be going for supplier pricing if not a smidge better (8k off sticker). Actually, I wonder if it is a tagged truck... Remember, 2017 model year are lower on incentive amounts until later on in the year. I only see $500 consumer cash on 2017 HD trucks. 2016 they have $2000 consumer cash. Incentives change monthly as well.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
