My truck has 600 miles on it and I'm already not thrilled with Chevy.... again. I'm coming from a 2015 Tahoe that was a piece of junk.
On my 2017 Silverado, I changed some of the VEHICLE (Comfort and Convenience) settings last night, like auto seat recall, reverse tilt mirror, etc. Got in the truck this morning and I didn't like them. Partly because my seat memory isn't saving. It keeps recalling to memory 2 for some reason.
So I have my truck running and am in park, and go to change them back..... Only option under Comfort and Convenience is CHIME. No scroll option or anything, the other settings are just gone.... WTF?
I also hate the park assist in this, compared to my Tahoe. Anytime it's cold out the Park Assist goes crazy and doesn't work right. Last night I was backing up and the front park assist was going off for no reason until it shut itself off apparently. Then I couldn't turn it back on.
Chevy has zero quality control and it shows... For me, it's 2 "expensive" vehicles in a row. Maybe I'm just that lucky.
as far as the comfort settings go read the owners manual and maybe find the default setting
park assist always does that there are countless customers at my dealer coming in with ice frozen on their sensing areas you cant control it... unless you have a garage....
The definition of insanity - When you keep repeating the same process but expect different results.
So all new trucks will have the exact same issues? I guess I'm missing your point in using this cliche phrase.
my memory seats kinda were the same as yours.. i got 2 key fobs with my truck from the dealer...when i tried to set it up on the original fob, it wouldn't work, so i grabbed the spare fob... for some reason my truck saw the spare fob as #2, and the original fob as #3... so i don't use preset 1... i'm stuck on preset 2... its not bad.. since i'm the only driver...so i dont sweat it..
You may try your other key fob to unlock the truck to address the memory seat/mirror settings. One setting is for each fob.
Edited by SkeeterMcSkeet
I have a friend that owns a Chevy dealership in a different town so I keep getting this crappy brand. But it's not convenient to take it to his dealership for service. And why would I need to be taking brand new vehicles in for service anyway??? At least that's my mindset. You're right, I am insane apparently.
Thank you. I will try that. My main concern is why my settings have disappeared.
I haven't had that happen, but I know I had programmed setting "1" for seat and mirrors and was using key fob "2"; kept unlocking the truck and the seat would be in a position that looked like an elf was in there driving. Once I switched fobs I was good. Good luck on the missing settings.
If I can't figure out how a feature works, I refer to the manual that came with my truck. After following the directions and the function is, or appears to be, malfunctioning I take my truck to the nearest dealership service department for assistance. I would not allow any new vehicle under warranty to be a piece of junk. I have purchased new vehicles (not necessarily GM) which have had an inordinate amount of warranty work required, but I always drive vehicles that operate properly. I am particularly concerned about how a vehicle holds up after the warranty period has expired. For me, GM's have always excelled in the long haul! Your Tahoe and Silverado are both great vehicles. The frustrations you have experienced can be fixed.
The brand as a whole I would hardly consider crap since there are countless people out there with GM products, like myself, who have had zero issues with their trucks. Its unfortunate you seem to keep getting trouble vehicles though. I would suggest checking the owners manual as previously suggested on the seat adjustments, could just be a step that was missed.
  • Like 3
This is from the manual... Last night I had all the options, this morning, I have only CHIME VOLUME.
Select and the following may display:
  • . Auto Memory Recall
  • . Easy Exit Options
  • . Chime Volume
  • . Reverse Tilt Mirror
  • . Auto Mirror Folding
Some of those functions require the ignition to be on. Perhaps this is one of those functions, I don't recall for sure.
If you're not happy with GM products, then don't buy them! Your friend wont go out of business! Go buy a Ford or a RAM or a Toyota.
That being said, I've found that most electronic bugs in these trucks can be fixed by shutting the truck down then restarting. They behave more like computers than cars these days. And believe me, it's not just GM. My wife has a Honda Pilot that hiccups once in a while.
I think the next truck I'm going to buy is going to be a late 1970's K 1500. I'll drop in a 454 with a 4-barrel carburetor...slap on a 6 inch lift and some 35 inch swampers....should be a good time, and no computers or gadgets to deal with!
OP has couple minor complaints and it is a crappy brand, funny since most people have no issues (as with every brand there will be those that have bad luck) as mine has been pretty much perfect. You don't like it move on, joining a forum to complain and insult isn't helping your case. Maybe you should make friends with a Ford owner or better yet a Dodge, ya let us know how those trucks are doing, they all have a laundry list of complaints...
These threads sure get old, hope you get what ever it is you were looking to get out of joining here!
Tyler
  • Like 5
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
