when i took the bezel off of my 2104 chev lt the wires when in the holes beside the heater controls
Damn, so as you can see in the photo above there are now there.
I'm going to remove heated panel and radio as soon as I got on days off from work and hope I find them in place.
Try to poke around a little deeper when you can. When I took out my X51R Fuse Panel, I found a pigtail harness taped back. Not sure what that was for but it's there for something.
It's hit or miss on the harness, I haven't found anything that shows when you might or might not have the extra harnesses. Even if you have them they won't work without BCM programming. The question is how the BCM works with the seat heater module and if you can replicate the signals directly from the switches. I have some ideas brewing but need to experiment. Potentially you could provide a cheap solution that bypasses theodules but still gives you full control.
So if my passenger seat is already leather and heated, but is a manual adjust, could I get the components to make it Power adjust?
Doubt it, guessing the frames are radically different.
Just ordered the dash switches for the heaters, trying to find a control module to test.
I guess I can look at my driver's seat which is powered and compare.. LOL..
I have a power seat in my LT guess I could compare it to my WT too, lol! I found a heater control module, should have some findings, good or bad, in a week or two. Actually excited to look into this as I was talking to another programmer today about how this is probably handled through the BCM.
It would be nice if GM stopped the heated seats from being controlled by the BCM, but I still think they do.
Tried to do this on my old NBS truck, was PITA and never worked.
I had the following to work with when trying:
Heated seats
Harness from vehicle
Door panel switches
BCM from vehicle
The schematic was pretty cut and dry for this and was a no go.
The power piece for a seat swap should be cake.
Yeah, I'll be analyzing the signals being related to and from the BCM and then basically replacing it with a small cheap PLC. Based on the drawings there are a couple of ways it could be interpreting the signal or even what the signal itself is but I have enough test equipment sitting around that I should be able to design a sub $100 solution.
Maybe this will help.
Heated and Cooled Seats:
Body Control Module
The body control module (BCM) monitors the heated cooled seat switches through LIN bus message inputs and determines the heated cooled seat operating modes and temperature levels. Each heated cooled seat is capable of operating in 3 modes with 3 temperature levels. The BCM controls the operating mode of the driver and passenger seats through separate pulse width modulation (PWM) signal circuits. Each mode and temperature level is commanded by a different Duty Cycle. The PWM signal circuits are referenced from battery voltage by the blower assemblies and pulsed low by the BCM.
Seat Blower Assembly Power and Ground
Battery positive voltage is supplied at all times to the seat blower assemblies through a 30 A fuse that is located in the I/P fuse block. This voltage is to supply power to the TEDs, the blower motors, and the seat heater elements. The heated and cooled seat system will operate only with the ignition in the ON position. Each seat blower assembly is grounded through the ground circuit and ground connection.
Each heated/cool seat has 2 blower assemblies, one located under the seat cushion and one located in the seat back. Each blower assembly contains a thermo-electric device (TED) and a blower motor. The TED is mounted downstream of the blower motor. Each TED consists of a circuit of positive and negative connections sandwiched between 2 ceramic plates. Each ceramic plate is equipped with copper fins for cool exchange. The air flowing past these fins is directed as conditioned air into the seat cushion and seat back or directed into the cabin as waste air.
Cooled Seat Operation and Blower Motors
As mentioned above in the seat blower assembly description, each seat blower assembly is packaged with a TED, blower motor, and it also contains logic that will allow for the blower to operate only when the ignition is in the ON position and only during cooled seat operation. When a cooled seat switch is pressed, the seat blower assembly applies a pre-determined voltage to the TED and blower motor. Then based on the feedback from a internal seat temperature sensor, the blower assembly controls the applied voltage to the TEDs and blower motors in order to maintain the desired seat temperature.
With cooled seat operation, the speed of the blower motor is not related directly to the High, Med, or Low input from the heated/cool seat switch. The speed of the blower motor is related directly to TED temperature. In order for the cooled seat system to operate to its optimum performance, it is crucial to have unrestricted air flow through the system. A dirty or restricted air filter, the blockage of an exhaust air duct, a misaligned blower assembly, or incorrect foam installation of the seat cushion or seat back will all have negative effects on the cooled seat system operation.
Modes of Operation
There are 3 modes available for the heated and cooled seat system operation; seat back and cushion heat, back only heat, and cool seat operation. When a heat or cool seat mode signal request is received, both the seat cushion and seat back blower assemblies will be activated. When the seat BACK ONLY mode button is pressed, the seat cushion blower assembly is turned off leaving the seat back blower assembly ON.
Heated Seat Operation
When the seat blower motor assembly receives a heated seat command, it applies a high side drive pulse width modulated (PWM) signals driven at the required duty cycles to generate the appropriate effective voltage to the heating elements to attain the commanded seat temperature.
This heated seat system utilizes a self-regulating heating element system, which is different from the non-regulated heating element systems with seat temperature sensors previously used on GM vehicles. In the self-regulating type of system, temperature feedback to a control module is not required for temperature regulation. The heating element material itself regulates the surface temperature based on the effective voltage applied to the heating element.
However if you're working on heated only:
Heated Seat Switches
The driver and passenger heated seats switches are located in the switch control panel. The body control module (BCM) monitors each switch activation to determine which seat is activated and at what temperature level. With each press of the switch, the system will cycle through High, Medium, Low, and then back to Off again.
When a heated seat switch is pressed, a LIN bus serial data message is sent from the switch to the body control module (BCM) indicating the heated seat command. The BCM serves as the heated seat system master to determine the requested operating mode. The BCM then sends a LIN bus serial data message to the seat heating control module indicating the heated seat command. The BCM also controls the seat temperature and mode indicators, via the serial data line, used to provide the operator with feedback as to the operating status of the system.
When the seat heating control module receives a heated seat command, it applies a high side drive pulse width modulated (PWM) signals driven at the required duty cycles to generate the appropriate effective voltage to the heating elements to attain the commanded seat temperature.
Load Shed Management
The electrical power management function is designed to monitor the vehicle electrical load and determine when the battery is potentially in a high discharge condition. The heated seat system is one of the vehicle loads that is subject to reduction during a battery discharge condition. For more information on load management refer to Electrical Power Management Description and Operation.
Awesome info Tbarn! I assumed it was using PWM for temp control, and I can replicate that easily enough if need be. The real question will be the signal being sent over the LIN network from the switches. Being that they are just switches I'm guessing they are using resistive signal like the cruise control system does. It's also reassuring knowing that the LIN system can only handle one command at a time so it should be easily decipherable.
If you don't mind me asking, where did you find this summary? This confirms some of my assumptions I was explaining to a fellow programmer yesterday when talking about this project.
Should be plug and play if you have the electric seats, at least for the driver. Did the WT2 come with the electric passenger? You can wire power to them and get everything to work, including the heaters, just not using the stock equipment as all of that is normally powered/controlled through the BCM. I am working on doing the same thing on a WT with manual seats and utilizing the stock push buttons for control but will be doing it all with custom wiring. Sounds like you got a hell of a deal on them!
Mr. Vader,
I am also looking to put Denali leather heated/cooled seats in my SLE regular cab with manual seats. I'd like a little more info on this wiring you talked about. I am fine with just hard wiring the seats for power and then use an aftermarket auxilary switch for the heated seats. Any chance at the cool function working as well? Do you have a rough sketch of what you did in this case?
Thanks
Looks like the seats I'm getting are cooled as well so they have the blowers on them already. Will this be a problem you think? As in plug being different?
Mr. Vader,
Thanks
Don't have anything yet as this is a work in progress. The heated seats would be easy to do with switches and probably resistors to change levels as the factory ones us Pulse Width Modulation to create the different temperature levels. That is the part I'm trying to find a work around for along with utilizing the factory switches (with custom wiring) to control it all. Cooling should operate much on the same theory. Without getting in to the deep technical jargon about how all this operates on a factory install, there are ways to replicate and what I'll be trying to figure out is if it is easier to mimic the BCM and use the stock heated seats controller or to remove both of them and create a completely new controller.
Any body happen to know if these 14-16 seats will retrofit back into a 99-02 Silverado? Does GM keep the mounting points universal through the years? I remember seeing someone do 08 seats in the previous body style, curious if they could go this route now.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
