Anyone else have a 14 5.3 that constantly whines? Almost sounds like an alternator going bad or something but ive used a rubber tube trying to hear what the sound is coming from and there is no one place. You can hear it pretty well in the video and the motor was up to temp when it was recorded. the phone is sitting on the plastic radiator cover with the hood open.
I've noticed this same noise since mine was new. Notice it more before the engine warms up. Dealer service says it's normal, although the tech was unable to say just what it was.
They all sound like that I don't know if mine has gone away or I just don't hear it anymore but it was very noticeable when I first got the truck
10 4 I figured that would be the general consensus is it was normal truck seems to run very good so didnt think it was to big a problem. Guess ill have to put a blower on it and maybe that whine will drown out this whine!!
Same noise here and my dealer claims it to be the fuel pump. Still it sounds like a 1986 Ford Taurus with a bad steering pump, annoying as hell imo.
Have you checked the PST fluid while it's running to see if it's foamy? Might be sucking air.
Sent from my SM-T350 using Tapatalk
I'm not sure about all the models but I think there all electric now I know mine is
I guess mine has a little whine. I don't have any issues and the engine runs strong so I am not to worried about it. Just turned over 70,000 miles yesterday.
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
(Normal) yes the DI engines make some unfamiliar noises. Once they get the electric propulsion perfected we will have no noise and we will really miss the Real motor noises. Make sure and save that video so the grandkids know what a real truck sounds like.
You should hear the GM 3.6 they whine way louder then the 5.3.
The DI engine in my truck makes less noises then my 2013 then the DI 3.6 the Traverse had.
To me it sounds like the new oil pump they are using. But as long as everyone else does it I'm ok I reckon. Now back to figuring out how to get rid of this vacuum pump.
  • 6 months later...
My 2014 makes this same whine noise. I bought the truck used and did not really notice the whine until i began driving it regularly. It is constant at low speeds cold or hot. I initially thought it might be the transmission but after this video it seems like it could be the engine. I feared it was a bad alternator or steering pump etc... Engine is running strong. I am about to change the oil so we'll see if that makes a difference. Anyone find out where the noise is actually coming from?
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
