Interior LED wiring help needed please
Need some help finding the correct power wire to use under the center console that only comes on when the truck is running for LED cup holder lights? I've tried the 12v plugs and USB plugs and they have constant power or at least enough to still power the 6mm led bulb even after the truck is off and all the interior lights have faded. I have footwell strips front and back that work with the dome lights but for the cup holder lights I want them on all the time when the truck is on if that makes since. Any help would greatly be appreciated
Are you wanting an ACC Voltage circuit? You want to be able to be able to switch it on/off? Only come on at night?
On at night would be ideal however id be happy if they were on when the truck key is on. When I wired them to the cigarette lighter or USB ports in the front of the console they were still drawing power even after the truck was off and all the interior lights went out which I thought was weird? I should be able to find a power source that stays on but only when the truck is on, hope this makes sense
And I like to not have to install a separate switch just for them if possible
Understood. The cigarette lighter and USB ports that are hot all the time is a configurable option (if I recall). There is a Fuse that can be moved so they are not hot all the time and will turn off after a specific amount of time. Similar to RAP (Retained Accessory Power). I believe you can tie them to Run/Crank Voltage, ACC Voltage, or RAP. Let me look into that tomorrow to see if there is one of these circuits are present in the center console wiring.
Here is a thread I found about the configurable fuse option. This may/may not help.
http://www.gm-trucks.com/forums/topic/176621-center-stack-power-outlet-options-rapfull-time/
I'll look at other options tomorrow...
Driver side fuse panel. Move the 50 amp fuse. To the position shown.
Left of brake pedal. Pull of the bcm plug box cover should be an open plug bank , tap the third on left. I had to solder on due to not being able to find a connector small enough fit.
Picture borrowed from another post.
I did 6 mil light in my cup holder, but tapped into the fuse block for dash with sensor. So they only come on at dusk and turn off when senses light..pic for ref..just fyi
shoot some pics when done
Gmdog's mod would be ideal! Could you please be a little more specific on where tapped into? I see the pictures I take it the black wire running down from the bcm block is the wire you tapped? Thanks again everyone for chiming in with ideas! If I can't figure Gmdogs way I may move the 50amp fuse to kill full time power to the 12v cig lighter and tap there
Hey Bowhunter1, I will get pics and for u today..sorry for the delay had some family issues come up..
Support the NRA
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
