Paint to match tailgate handle
I found a ptm tailgate handle (23128692 PTM) and I was wondering if it will fit a '17. I've only seen them say they go from 14-15. And my tailgate locks with my remote, would that work with it if this handle does fit?
Where did you find this at? Is it from GM?
It's not a GM part. It's made in Taiwan. I bought a PTM handle from Amazon. It fit fine but the handle isn't as solid feeling as the factory part. I had to swap part of the linkage and a spring over from the factory handle to get the power lock to work.
8CDFFD18-4FF9-44B9-94E1-21E32535597A_zps
587B83CF-4E87-4C76-8E18-741338876E8F_zps
4D91D7FD-6E1A-43AF-A943-5829AD6144B8_zps
I vote for just having the oem handle smoothed and painted. If I had to do mine again, I would separate the handle from the bezel to make it easier to paint.
I painted it myself. Start with 180 to knock it down quick. Finish off with 400. I didn't want mine like glass so I just used adhesion promoter/paint/clear. You can use adhesion promoter and then a sandable primer. Wet sand that with 800 or so and then paint/clear. Follow up with a good wetsand and buff and be careful around the edges because you can burn through.
So how many coats of each should I use and do you recommend any brands of adhesion promoter primer and clear or are they all about the same?
I got mine from summit racing. I did 3 light coats of black and 3-4 coats of clear so I could wetsand and buff. Just make sure you use a 2k clear. Spraymax in a rattle can is what I used for my headlight trim since it was small. You can find it on amazon. I went to my local paint shop and bought a pint of black and clear to spray my grille and tailgate handle with my hvlp gun.
  • 3 weeks later...
I agree with the 2k clear. You can get them on Amazon or ebay etc.. they're expansive but well worth it. Puts a real hard coat like factory.
  • 1 year later...
Got a part number?
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
