Windshield Wipers
NOT AGAIN!
Ok, so I've read plenty of threads and everyone says "Bosch Icons"! Yeah, they are pretty awesome!
Sadly, I have a 2015 with some stupid new clip design and Bosch doesn't make set for that year. I even called them.
I got some Triflex Teflon crap whatever from Advanced Autoparts and they suck.
Any recommendations or should I just go to dealer and get OEM?
The ones I have streak and chatter like a drunk girl at bar.
Well, geswek, reading your post got me thinking. I also have a 2015. And due to my using a daily driver work beater and the truck living in the garage til the weekend, I have not needed to replace my blades yet.
I didn't know they were a goofy clip/arm. I did some looking and it appears the arm we have is called PTB (Pinch Tab Button)
Rain-x sells several of the beam style that fit: https://www.rainx.com/blade-size-finder/
some blades I have bought in the past from the local Fleet Farm come with all kinds of adapters that i thought are able to fit any arm style.
I have found that even cheapo blades work fine for a while. The key is to keep your windshield and wipers relatively clean so that when it does rain, you are not smearing bug guts and dirt around on the glass. I have been in the habit of washing my windows every time I get gas (learned that from the old man). I generally have no streaking problems with any of my vehicles. And when I do, the blades get replaced.
side note- do you have any other foreign materials on your glass?? bird poop, tree sap, or even wax or rain-x that you apply can affect how the wipers work.
NOT AGAIN!
I just bought a set of Bosch Icons and they work fine. They have an adapter on them when you unpackage them. Take that off and they fit.
https://www.amazon.com/gp/product/B000BYGE3M/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
I park in garage at work and at home every day -- my first set lasted until now and I bought truck in December 2015.
I don't think anything is on it; but I do need to wash it.
No kidding?! On a 2015?
So just pop the adapter off it and they'll snap on?
Why not just refill with OEM? How often they get changed is way more important than what with.
Yep i have a 2015. I was pissed when i initially bought them because they bracket was too large and they wouldn't fit. Played around with them and found that the bracket comes off and the correct one is underneath it.
I wonder why Bosch doesn't list these on their website? They say there is no PN for 2015 Silverado 1500. Even Advanced said the same--though I take her comments with a grain of salt.
RainX extreme clean works well on glass that normal glass cleaner won't clean...it's a paste.
NOT AGAIN!
What Hey_Fam said... when you get the Icons, make sure you get the "22OE" not the standard 22. They work fine, you just remove the extra clip from the new wipers and they go on just like OEM. The 21OE are on sale on Amazon for $10/ea right now. One member here said he preferred that size. I'm using the 22 and they are fine, but I might grab a pair of 21s as a backup.
Thanks!
I just made order on Amazon for mine and also some Icon's for my wife's CX-5.
I love Icon; just got annoyed that it was said they wouldn't work. LOL
I have a 2015 Sierra and I just installed some bosch icons last week. 22 OE both sides. Just have to take off a cover that comes on the wipers and they click right in.
Thanks!
Just go OEM. The OEM blades used to suck but the last couple of years they have gotten much better (and they're made by Bosch anyway). The cost of the OEM ones used to be high too but they are much more reasonable now.
I used to swear by Icons but the last few vehicles I put them on they put too much pressure against the windshield and did not clear correctly.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
