Dimming screen?
10-4 thanks for the clarification on that, I wanted to make sure I was watching for the right thing as I have not noticed this on my 17 (only had a short time and never really drove much at night yet)) and never noticed it on my 16 Denali either though so if the 17 does it I will take note. These things are supposed to improve not go backwards LOL.
'14, '15, and '16s don't do it, even though the infotainment and backup camera system is practically identical. I came from a '14 SLT and it definitely didn't do this. The problem is unique to the 2017 Sierras and Silverados.
  • 4 months later...
  • Replies 41
I have the same issue with my 2017 Silverado. After a few weeks of being annoyed by the brightness of the screen, I called my service department. I had to convince them nothing I tried would dim the screen, and even had to send a video to the service manager to show how bright it gets.
Fast forward to the day of the appointment. They look at my truck, say there is nothing they can do, and write the cause up as "customer has tinted windows" which was preventing seeing out the windows.  I told them that was not the case,  as I just had the windows done a few days before the appointment, and I noticed it before the tint. I even mentioned upon checking forums, that others mentioned the problem.
They did research with GM, and apparently they did have a documented issue, and were waiting for a software update to fix, and they would call me when the update was available.
After a couple months, I got a call that thw fix was available, and I am going to have my truck updated tomorrow. Hopefully this fixes the issue.
Traded my 14 Silverado in a 17 Silverado last September, the screen brightness was blinding to me at night.
Took the 17 in on Monday for the software update, all is good now!
Thanks to this site, I knew the 2017 Silverado's had this issue, to bad GM couldn't follow up with their customers, guess there too busy building new trucks?
Yes the fix came out last August I believe. I still need to get this done. It’s annoying as hell.
Just returned home from the dealer. Fixed, I hope.  Thanks for informing me that this is a known issue.  I'll update tonight after I try it out; for now I just wanted to give a minor update on what I found out.
FYI: They took my truck in and in 45 minutes or so it was returned to me with this comment from the tech:
" See Bulletin 17-NA-269: Rear Camera Screen Bright At Night Reprogram Radio Controls".  Unfortunately, I don't have a copy of the bulletin itself.
Unrelated info but I changed out my reverse bulbs to the LED's (Sylvania Zevo 921's), which look awesome, but don't seem to provide any additional lighting.
Hope this helps.
My '15 stays dimmed down when I put it in reverse.  I only wish that I could dim my interior lights, displays 50% further at night, lowest level is still a little too bright for my liking.
I recently purchased a new 2017 Silverado. I have purchased at least 20 vehicles  from the same dealership since 1990. I  know that GM is aware of the problem with the backup camera in the 2017 being too bright at night and that you cannot see out the mirrors. I traded a 2015 in on this vehicle. The 2017 camera does not adjust with the dimmer switch at night as it should. GM's fix for this is to re flash the module. The only thing this accomplished is to limit the background lighting of the dash and infotainment system. The ambient light censer is not sensitive enough to ambient light so the dash and infotainment screen is not bright enough when the sun hits the infotainment system screen but does not hit the censer, or when it is cloudy out. This is a real problem. I also noticed that there is no setting for day, night or automatic for the infotainment screen as there was on all my previous vehicles. I would rather deal with the bright camera. I have read here on this topic that The August flash fixes this problem. I had my truck re flashed in November of this year. As I stated above it only limited the background lighting. No dimming with dimmer. Can anyone confirm that the latest firmware flash allows us to use the dimmer for the back up camera? I know the main screen dims with switch. I wonder if this is really a hardware problem.
Make sure the dealer applies Bulletin 17-NA-269.  That seems to be fixing it for most people.
I had this done back in august and my back-up camera now dims with the rest
I haven't taken mine in yet, but I believe it to be a software issue.  It gets crazy bright when I shift into R.  But gets much more reasonable in the 2 or 3 seconds that I bump into N before going into D.   I would think if it were hardware it wouldn't dim down for that second or two.
Looks like I’ll be making a trip to the dealership before my first free oil change.  This is one of the very first issues I noticed on my 2017 Silverado.  The night I brought it home I backed it into the driveway and was blinded by the back up camera display.  Silly me, I was trying to use the mirrors to back it in and couldn’t really see out the passenger side.  Since mine has a March 2017 build date, I guess I’ll have them check for the transmission software update too.  Maybe I can get my two biggest annoyances taken care of with one trip.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
