mine got 15 city/17-18 highway when it was 100% stock.
its funny they have all this fuel saving technology on these shitboxes but they still get horrible mpg
I prefer driving a pickup and a truck has been my primary transportation since 1971. The new pickups get exceptionally good mileage over their predecessors which makes them a viable vehicle for everyday pleasure use. I thought I would have to give up driving a truck during retirement because of the cost of operating, but no need!
I don't know about that, my 2004 Silverado I traded in for my 2014 got a consistent 20mpg. and it had 212k when I traded it in. same cab config and both 4wd trucks. both 100% stock.
doesn't matter much now, with my new 35" tires ill be lucky to get double digit mpg
Not exactly surprising considering most of the information posted on this forum is how to remove said technology in pursuit of power, aesthetics, off road capability, etc
Edited by Bushleaguechew
I do know that all vehicles are tested on 100% pure gasoline and not an ethanol mix when the mpg ratings are developed for the vehicles during manufacture. So the sticker on the window will almost never be what you get.
Not to mention the EPA tests are done on a controlled course at something like 55mph. So the number on the the window sticker labeled "highway" is inherently false from the beginning.
If they want to tell us a true "highway" mileage, the test should be done at 70 mph min.
I'm wondering why I'm get really poor mpg. All I have is a lvl kit with all terrains and a k&n air flow. On average I'm getting about 15 with no trailer and feathering the gas pedal to keep in v4... I'm not sticking my foot in the floor board all the time to hear the k&n roar[emoji848]. I see a lot of you guys getting 16-19 with pretty much the same setup. I think I was getting better mpg without the k&n.
I average about 18, but my problem is trying to stay out of the throttle. Two weeks ago I got almost 20mpg on a tank, but I didn't go over 60mph, I tried again this week but was running late monday and tuesday the DIC is showing closer to 17 when on Sunday it was showing 21. I have Cold air inductions CAI, 33'' Duratrac, removed the front airdamn, trailer mirrors, magnaflow off road cat back.
My daily drive is 8 miles each way in city traffic, so I average about 16 - 17 mpg if I'm lucky. When I go on trips, I easily get 22+ mpg on the interstate going 65-70 mph.
Let's not forget the few asshats here that claim 25+mpg running 80mph; and the one that claims almost 30mpg.
You have an interesting handle. I like it, It fits perfectly.
Crew Cab Z71 5.3. Deep gears and a 4 X 4 with a lift kit and off road tires. Yea, your K&N has nothing to do with your mileage. Isn't hurting it anyway. I run one too. Replacement type.
I'm the a$$hat I believe 'dork weed' was referring to. :dunno: They put the same sticker on all the Silverado 1500's making one distinction only. 2WD or 4WD. 24 mpg and 22 mpg respectfully. that is highway mileage. Dollars to donuts says the one they tested was similar to mine. RCSB 4.3 WT1 2WD and then guessed from there and guessed WRONG. There is a half ton or more of weight difference between yours and mine. A liter in motor size. Your run a good deal stiffer gear ratio. (Z71) Are 4WD. Run off road tires. Lifted. I run a bed cover. That's the difference in trucks in a nutshell.
Drive wise, even if you are prudent, if your trips are under 35 miles in the summer or a hundred in the winter (between trips where you completely cool down) your never fully warmed up. (watch your trans temps as an indicator not the water temp) If those trips are urban then there is a great deal of interruption in those miles. Lots of accelerating the load and even if done mildly they take a fair amount of fuel. Late to initiate stops waste huge amounts of fuel. Scares the crap out of cross traffic too and kills the brakes. Stop lights/signs, trains and traffic patterns kill mileage as well. Weather and terrain have an effect. And lastly I'm here to tell you that the difference between 50 mph and 70 mph is HUGE. Even in my rig. There is a wall you hit about 53 mph where the air over the truck looses the boundary layer and the truck becomes like pulling a fish net though molasses. If I run 70+ into a headwind of only 15 mph I can drag mileage down to under 17 mpg. Same trip at 55 nets 24-26+ mpg. I can run 65 mph with a tail wind on the Interstate and pretty much get 28 mpg at will. Slower speeds have netting a high of 32 mpg for a full tank of over 500 miles on my tiny teeny 26 gallon cell. 30,000 mile average over 10 months is a dead 26.0 mpg.
Now, all that said. I an not implying you have all those habits but you know which ones apply. Use what you can and ignore as much as you like. I don't buy your gas. :seeya:
I'm running KO LT285/65R18
I don't see a recommended tire pressure on actual tire. Just max of 80 psi
2.5 lvl kit
Edited by Clint623
The 21 miles per gallon was in the hill country. I guess my truck really likes Central Texas
Edited by Clint623
2.5 lvl kit
It's going to be very close to your original sticker pressure in your door jamb.
Good looking rig. Getting 15mpg with a level and 285/65R18 sounds about right. I get about 17.5 average per tank with a level and smaller non-LT tires than yours. I expect when I go to 285 or 295 tires, I will be in the 15mpg range.
Post up some more pics of your rig with those 285s. I'm torn between the KO2s and the Nitto RGs.
I've got the regular KO's ( old style A/T) I saw the KO2's today and they look pretty awesome and pretty sure that's what I'm getting next. Nittos may be a little too aggressive for all the hwy driving I do
6.2 8spd CC 4x4 I am seeing about the same mpg on this almost identically equipped 17 as I did my 16. Around 20.5 mpg average over 19,000 miles on the 16 and currently right at 21 mpg over 1500 miles on the 17. It really is mostly driving habits that produces the good mileage, I just like driving like a grandpa because I can. I know that if I wanted to I could burn over 90% of the vehicles on the road. I could probably take the OP's truck and wring out around 19 or 20mpg easily over several thousand (pretty boring) miles. So OP just drop it off with a credit card for fuel and I will run it a few week or months to see what we can get mpg.
Edited by MyFavTruck
We can trade. I'll pay for gas in your truck and you do the same for mine.
[emoji106][emoji857][emoji389]
Edited by Clint623
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
