I'm wondering why I'm get really poor mpg. All I have is a lvl kit with all terrains and a k&n air flow. On average I'm getting about 15 with no trailer and feathering the gas pedal to keep in v4... I'm not sticking my foot in the floor board all the time to hear the k&n roar[emoji848]. I see a lot of you guys getting 16-19 with pretty much the same setup. I think I was getting better mpg without the k&n.
Edited by Clint623
What kind of gasoline are you burning? Octane? Brand? Even if you don't have your foot to it, just driving at a high rate of speed drinks gas.
Edited by Justin101714
I average about 15 as well but dip down to 14mpg with all city driving. I'm not sure how others get higher mpgs.
My average weekly commute is about 40 miles per day with 10 miles on the highway.
I always do my gas mileage out on a calculator after filling up because I found the trucks estimation is always high
Also worth noting, my truck is bone stock except for running 22 inch oem wheels
Edited by TomN
Just regular gas and sonoco 9/10 times
There's just lots of variables as to why poor mpg happens. I drive about 30 miles to work one way every day and my average is around 18-20. Just kind of depends on so many things it would be next to impossible to give you a true reason. I do know that all vehicles are tested on 100% pure gasoline and not an ethanol mix when the mpg ratings are developed for the vehicles during manufacture. So the sticker on the window will almost never be what you get.
what speed are you driving to get your 15mpg? driving around town, that's pretty normal.
freeways can be deceiving too, because if you are driving 75+ on wide open freeways you will get way worse mileage than someone who drives 60 on rural country 2 lane roads.
The others have already discussed how your level kit and tires probably did lower your fuel efficiency a bit. But keep in mind your tire pressure can also affect it. Driving with too soft of tires creates a lot more rolling resistance. I would check the recommended tire pressure from the manufacturer. (recommended, not the max that is listed on the sidewall) Your truck sensors may think you are good at 35 psi, but the tires may actually want 45 psi in them. A lot of people don't think about this when putting on aftermarket rubber.
I drive 40 miles one way to work in central texas, the hill country. If I use cruise every chance I get at 2-4 miles over the speed limit I am around 16+ mpg. That is with stop lights and hills and a little highway driving. When on the open highway I can get 18-20+ if I don't drive to fast.
These guys getting 20,22,24+ mpg must be cruising mostly at 40-60 mph on flat roads. Or 60-70 on good flat highway with NO lights.
2014 Silverado Z71
Edited by Knotsure
Currently I average around 10-11 on my daily commute to work. I have about a mile with two traffic lights. The engine never reaches operating temp and the mileage reflects that. But even so it's been three weeks since I filled my tank and I've got plenty left [emoji16]
I have an 84 mile round trip every day for work. 90% of that is on 55mph county roads and 65mph highways with 3 traffic lights (and a couple of railroad crossings) the whole way. I average 21.6 (done by hand the last time, not the DIC). I pretty much stick to the speed limit, and watch how much I dip into the throttle. I can make my mpg drop quickly if I really want, but if I'm careful, I really do get pretty good mileage.
Edited by OldBlue61
mine got 15 city/17-18 highway when it was 100% stock.
its funny they have all this fuel saving technology on these shitboxes but they still get horrible mpg
i did not know that...good info thanks
2014 Silverado Z71
Let's not forget the few asshats here that claim 25+mpg running 80mph; and the one that claims almost 30mpg.
What size level and what tires/size? I am guessing you went with the infamous KO2's that are one of the most aggressive and heavy AT's (mostly come in E load range) as well as I am guessing a 2-2.5 level? That combined with 4wd did it. Next time maybe lighter tires and a 2wd truck will fix your complaints?
Tyler
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
