What tint are you guys running with? Pics?
  • Replies 68
Here's the inside pics 9cadd3e15b7faa906848f16e0d45f5e2.jpg60528569a5b39ea91b6a88b7b6569503.jpg6feb72ec39599f23d1554dd0e7339386.jpg
Did you paint your tow hooks?
I'm also from the 301
wow! gorgeous rig!!! :drool::drool::drool:
They are the red ones that come on the new "redline" edition silverados
Thanks!
30% here, slightly lighter then the rear, but still some privacy, and with a no tint law, we don't get hassled by the cops...22808d18c685696f2e49402d90946b3a.jpg
Sent from my XT1254 using Tapatalk
I run hybrid ceramic tint which actually blocks IR as well as UV so it does better at controlling temperature. 18% on front doors 5% on rear doors and back and then 55% on the windshield with a 5% sunstrip. Keeps interior nice and cool and don't need to wear sunglasses when driving.
how is seeing out of the windshield at night? i want to get mine done but not sure what % to get
The windshield isn't bad, occasionally backing up I roll down the windows to see better out off the side mirrors when I need to get into my garage. I will be doing the same on any of my future vehicles. Love the way it looks
Where did you find said tint
Sent from my Pixel using Tapatalk
My buddy owns a wrap and tint shop. It's made by Suntek. They make standard tint, a hybrid-ceramic and a full ceramic. The full ceramic is really expensive. The hybrid is a nice in-between. For a full install all the way around including windshield expect to be around the 500 range which is about 50% more than standard. But my wifes Camry has the same level of standard tint all the way around and my truck was about 10 degrees cooler on a 90 plus degree day last week when I checked with an IR temperature gun. So I'd definitely say it's worth the investment.
I just did 20% over existing rear tints, 50% over existing front doors and 20% over existing eyebrow. Will post pics later.
  • 3 weeks later...
I did 5% on the rear window and doors and 20% on the front doors. d64ffc70da53fe0b8105a26d9b66cfc5.jpg
Sent from my SM-G930V using Tapatalk
I have 35% on the front doors, a 5% strip across the windsheild and the rear is all stock.
20170430 090403
3M high performance. Stock windows in the back were covered with double layer 5%, front 2 windows is a 5% layered with a 20% and the windshield is 20% with a 5% top strip. Nice and dark no you cannot see in at all!!!!
5% on doors and back window and 35% on front window
One word... Illegal. lol
But 20% all around with 60 covering the front windshield with a 5% strip
Hope your still joyful when your insurance claim is denied. In the case of an injury accident you'll be cutting an awful lot of really big checks...
I'm completely stock and of course "legal" as well.
lmao
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
