Max sustained RPM?
2016 2500 Gas double cab. While towing about 7500lbs sometimes to maintain highway speed (65) the truck will drop down in gear to rev at about 4500RPM. Is this okay to sustain for the duration of the grade. My Dodge would do the same thing and I always felt I was going to see a piston shoot through the hood. I also noticed once the grade eases up it doesn't like to up shift.Takes a while before it will drop the rpms. My 1500 towing the same trailer didn't do this nor did it run as high an RPM as the 2500.
Thanks
Shouldn't hurt anything... not as long as you have good oil. The 6.0 is pretty underwhelming. We have some at work and they don't have quite the power of my 17 5.3
How long you are running at high RPM is probably the deciding factor. The 6.0 makes peak power at 5400RPM so 4500 is certainly within the parameters for the engine but the engines aren't intended to run constantly at peak power, or at least not if you want longevity. I'm not afraid to turn an engine up if the need arises but at the same time I try not to thrash my vehicle if it's not needed. If a Kraken is chasing me up the hill then let her wind, otherwise I'll let the speed drop a bit on the grades and let the engine operate where it sounds happy. :)
But I'm just some guy on the internet so take my thoughts with a grain of salt.
The rpm's are not going to hurt it. Just watch your coolant and transmission temps.
This is correct. The engine is designed to hold up under extremely heavy duty cycles, and your computer is programmed to protect your engine. The best way to tow with a gas engine is to (1) buy a truck with a heavy-duty engine with a long track record of reliability under demanding conditions and (2) let it rev all it needs to in order to pull the load you need to pull.
You have already accomplished 1. Now you need to relax and do 2.
When I have pulls like this, mine will sit at 5k for several minutes. The only thing that creeps up at that RPM is engine oil temperature, which I have seen low 240s before (just this past weekend); trans and engine coolant tend to stay put.
Sent from my SM-T350 using Tapatalk
Didn't know the newer 2500s had an oil temp display, pretty cool. 240 is still well with oils designed operating temp
They don't, I have a standalone reader...
The engine will hold together just use a good synthetic like Mobil 1 or Pennzoil platinum....
Curious if you can share how steep the grade is, and how long?
If you're referring to me, I pull Seven Mountains on US 322 going to State College, the main grade is around 4 to 6% (about two miles with curves) and the last half mile or so is 8 to 9% (maybe greater) from what I remember (it's steep and has a 90 degree curve right before that increase which makes you lose momentum). That last half mile is 2nd gear and near redline, and like someone else stated, once the truck makes the decision to drop to 2nd, it stays there until well past the crest of the top; leaving out of the throttle only slows your speed, it will not upshift to 3rd.
This grade will bring most tractor trailers to under 20mph...with 3.73s and near to 5000 pounds of camper, I can typically maintain 45 to 55mph even at the top.
One other thing to remember is that these trucks are smarter than you think, more than once I've had this one limit throttle and shifts, probably to preserve longevity of the drivetrain. I would guess they would pull back power well before you would ever get in danger of a catastrophic failure.
I don't know the grade. Its not like Rocky Mountain steep just the hills of VT, NH and ME. Thanks for the responses. Next time I will look at the incline gauge and see what it is.
A lot of times the signs descending a grade will have the percent grade.
Thanks. That sounds like plenty of power to me! I am surprised to hear the grades are that steep in PA, I doubt I will see many grades that steep even in northeast WA and north Idaho.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
