1500 with Max Trailing package
Running an equalizer hitch.
Shocks were purchased from MRT, they are a sponsor here.
  • Replies 44
Thanks - Is a 4-way alignment needed after strut replacement? You had them put in at the dealership or Les Schwab or?
Would recommend an alignment anytime something gets moved around suspension wise.
Just some info for the mix.
GM made huge upgrade to frame, front end and brakes of the HD's in 2011. (and the brakes were already larger than the 1500)
At thetat time, they also did away with the small tank on the HD, and increased the size of the tank on all HD's.
Frame of a 2500 is massive compared to a 1500.
No amount of of airbags, helper springs etc will improve the capacity of the rear axle bearings and the differential (but admittedly we don't hear of problems either).
Assuming truck will be a double or crew,, the 1500 will have a 98L/26USG tank.
A 2500 will have 136L/36USG tank.
When I towed interstate from the great lakes area to Arizona mine 5.3 was always in single digits per gallon.
22 gal x 9.0 = 198 miles between fills.
32 x 9 = 288 miles, still not great, but it's 1/3 further.
Makes quite a difference on a long couple days towing. At lot less stopping 'now' because the next station is beyond the available range. Especially in the west where services are not as frequently available.
Truck choice also depends on how far, how fast and how often it will be used to tow.
Big difference between running 2 lanes vs trying to run long distances on the interstate at +/- 75.
Hello everyone. New guy here.
OK I have a bit to add. I am pulling a 28'flatdeck with a 10'camper on it and 2 quads. Tung weight is 1200lb and the axles are 9200lb so total 10400lb. I have the 6.2 with 8 speed, air bags, equalizing hitch with the 800/1200 bars. I upgraded the shocks to procomp. The truck is lifted 4" on33" load range E tires. It has the 3.42 gears and the nice tow mirrors with led backup lights in them. I have 25000km. Yes I am from Canada. I pulled Calgary to Golden and back. 800km through the rocky mountains and got 23.4l/100km or 10 US mpg. The rear axel weighed 400LB over the max rating but otherwise I am in spec. Power is not a problem. I used to pull the same setup with my 06 Duramax chipped with banks 6gun and I pulled Calgary to Moab UT for a month total 6000km avg 21l/100 km or 11-12mpg now I weighed 20000lb with the dmax setup because I carried all my tools as well. And the rear axel was right at the max of 6600lb! So the halfton is not carrying the tools so total weight is like 17000+. It pulls well considering it is a halfton. I would never attempt it with my old 1980 heavy half with the 350 farmer 4speed. The brakes on the truck are bigger than the dmax ones by a full inch front and 1.5 on the back,
So for me it I think it is on the edge of capacity and I feel safe driving it. I miss the avalanche of torque the dmax had but not the ride and cabin noise(speaker phone impossible in the dmax) I am going on another trip to northern Alberta shortly and I am installing my wind deflector. Which I didn't have last time. So I will post again when I get back.
Asked MRT for a shock recommendation for towing with Max Trailing package - they did not mention Fox..........
The Bilsteins have always been a popular upgrade, and on the new models it seems the 5100 version of the shock has the best valving & dampening characteristics for the 2014+ Silverados. Bilstein does not recommend their products for any truck equipped with max-tow packages as that big rear leaf can overwhelm them, although they are still an upgrade from the factory shocks. The fronts will work just fine tho, its the rears where a more substantial shock may be needed. The fronts should help keep it more planted and eliminate some of the front end bounce you experience when towing. I will do a little research and see what I can come up with, we see maybe one max-tow package in ever 250 trucks we work on! Let me know if I can answer any questions.
BTW even on my 2500 hd I used Bilstein 4600 HD shocks. Night and day better!
So did I on my 2007 Duramax - made it very planted over railroad tracks etc.
In regards to payload, in the future if I upgraded to airbags along with the stiffer Springs that already come with the max towing package and a good weight distribution hitch would that work to help with payload?
Legally, I would say no. With that said on my NHT I put airbags on and it help tremendously. I have since moved from a TT to a 5th wheel and upgrade to a 3500 dually. Probably overkill since we only go out 3-4 times a year but I'd rather be safe then sorry.
I spoke to a Bilstein tech rep. They did not recommend the 5100's for the NHT trucks.
Was never able to get anyone @ FOX to call me back or pick up the phone for that matter.
But after a bit of research and speaking to the guys at MRT, I went with the 2.0's
The Kings and Icons are overkill for how I use my truck.
All I can tell you is the 2.0's made the truck much more stable.
The front end pogo-sticking is gone and the rear end feels much more planted.
I had them installed at a local shop that knows suspension.
These threads crack me up, they pop up often... IMO it comes down to how often you tow.... I've pulled 10k 3 or 4 times with my 2016 1500 5.3, 3.42 gears and a insight brake controller... I had to go about 15 miles one way with a backhoe on 35mph back roads.... I wouldn't want to have taken that combo on the highway just because the trailer is so much heavier than my truck it pushes the truck around a lot... I pulled a 16x8.5 car hauler enclosed trailer a lot last summer when we moved that was a breeze and I would do it on a regualr basis with my truck without hesitation.... If your truck is mostly going to be a DD you'll be ahead by going with a 1500, if you need to tow a lot of 6k+ loads more than a handful of times year I'd start to consider the 2500 since it will get better MPG and be safer/more pleasant to operate while towing. Just like there ain't no replacement for displacement there is no replacement for weight in a tow vehicle.
I've seen a new transmission shaft break on one short trip with a heavy load. Twice. I've burned up brakes on steep hills with light loads on much heavier trucks.
I don't think it's about how far or how often. It's about how much margin you have when the unexpected happens.
Imo when towing 10k+ yes, the added weight is stiffer frame, heavier suspension components, bigger brakes. Could you upgrade the suspension on a 1500 yes, i did air bags next is sway bar. Then brake upgrade
Sent from my SM-G935P using Tapatalk
You still have a 1500 semi-float axle and can exceed that capacity...regardless of the suspension upgrades, it's still a 1500.
Its like putting lipstick on a pig, it's still a pig...
  • 1 month later...
Hi Guys, new here.
Was 2015 the first year for the 2015, 8 speed, 3.42 option?
Did any years before 2014 have a 6.2, 6 speed, 3.73 max tow option?
Thanks.
Update. I thought I would share how the last. 5000 miles of towing have gone with the truck. I have been over the continental divide twice and up to northern Alberta this summer. And my weight of truck and trailer has varied from 16220lb to 17450lb. basically carrying 1 quad and gear or 2. I am happy to report that my average fuel economy is 12 mpg US. The truck has pulled like a champ. I also have discovered that there is no way we can tow 10000 to 11700lb trailers and be legal. I have weighed my self several times and also converted a porta power with a gauge to weigh the tong. the front axle is in door plate but the rear is over by 200 to 400lbs. depending how I distribute the load from trailer to box of the truck. The rear is still 500 lbs less than the rims are good for which is 5000 lbs. And get enough tong weight to stay away from the death sway that happens with too little.Other than that it handles it well. Now my rig is not standard issue. Now the pics will say it all but I have arrived at my first question.
How do I make my pics small enough to fit on this site. I am not savvy this way. Because I want to show you what I am running. And my pics are too big like 11MB. Thanks in advance for some tips.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 556 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
