On 6/18/2018 at 9:47 PM, Nasty said:
My clunk was due to the driveshadt inout splines needing more grease
How hard was it to grease this? just remove the drive shaft bolts and drop it down and grease?
Is it pretty straight forward?
Yes.  Hardest part is jacking up the truck (im lowered so i had to)
  • 4 months later...
I purchased a 2018 Silverado in September of 17. I have approx 7200 miles on it today and noticed the “clunking” sound coming from the rear. I became concerned that it may be drive line related. After reading the posts on this thread I checked the leafs first. As a quick fix I sprayed some oil on the springs and let it sit over night. The next day heading to work as I pulled out the driveway “CLUNK!!” this time only worse. It was to the point that when driving down the road if I jerked the wheel back and forth at 35mph it sounded like the lug nuts weren’t tightened on the rear wheels. So I decided I’d come home and slip some thin pieces of rubber on top of the existing pads on the leaf springs. (Just as confirmation it was the springs). So I did as the others said. Jacked the truck up and used a crow bar to space them out a bit. Used some degreaser and a rag and cleaned the factory pads. Placed the thin rubber pieces on top of the existing pads and let the jack down. Backed out of the driveway and “SILENCE!” No more clunking. I will now be looking into a more permanent solution now that I know what the problem is.  I hope this helps.
Matt
  • 9 months later...
On 8/25/2017 at 1:17 PM, paumat said:
here is how I did mine:
1. Get you some bicycle inner tube or rubber sheet (HD sells in plumbing dept)
2. Raise truck from frame on driver side just in front of rear wheel.
3. Use jack stand for safety
4. Use large flat blade screwdriver or pry bar to separate leaves at front of spring
5. Insert rubber piece then remove pry tool. keep your digits out of harm's way
6. Repeat 4 & 5 at rear of spring
7. Repeat 2-6 on passenger side
Just did this this morning and when I shake the bed side to side the only noise I hear now is a little axle play; spring clunk is gone. We'll see how long it lasts. Fluid film was getting me about a month before the noise returned.
Anybody know if the piece he inserted is that little white piece?  Hows does it stay in there?
Yes, it’s the orange rubber sheet between the leaves. The leaves are tight enough that it won’t come out.
You can buy rubber poly spring liner in a 20 foot roll . it has lip on both sides to hold it in place on springs . It cost about 16 bucks a roll. speedway motors has it and I think summit racing may too.
I know this is an old thread, but I have a squeak or a creek noise coming from my leaf springs. Its driving me crazy. When you slowly come to a stop, you can hear it and then when you take off again. Sounds like a creaking door opening and closing. Only happens when you move forward or come to a stop. Jumping up and down on the truck wont do it, only accelerating from a stop and coming to a stop. It goes away when the truck gets wet or its raining, then returns.
2020 6.2 Trailboss LT here, I also have a "clunk" in my rear end. 9500 miles on the truck, not sure if it's leafs or the axle. I'll be calling the dealer this week,.
2020? You might be better off on the other forum?
Dunno, there may be more similarities than I'm aware.
I just noticed the clunking sound in the last week. If I stand on the bumper and bounce up and down I hear nothing. If I shake the bed side to side I hear it. Does this still fall under leaf springs issue?
  • 10 months later...
I know it was 6 years ago, but thank you for the instructions and pictures paumat.  My 2018 has been to the dealer several times for this over the last couple years, and they didn't have a clue how to fix it.  They finally told me "that's how they all are".  10 minutes and some bicycle inner tube and the clunking noise is gone completely.
This post is old, but anyone who did this years ago, how long did the fix last?  I'm not expecting the rubber inner tube to hold up to the springs rubbing for long, and I'm considering different materials that might provide a cushion but be more durable.
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 843 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
