Lately my tailgate has been dropping straight down as if it didn't have the slow lowering and lift assist. Upon inspecting, I noticed the little rubber bushing in the corner is torn and crushed. Should be something covered under bumper to bumper correct? If not has anyone had to replace it and know the cost?
Edited by Bushleaguechew
There are two parts that might be causing the issue. There is the bushing(#2 in diagram), which is GM 25815554 list $6.05, and there is a hinge damper (#5 in diagram) GM 23115812 list $94.28. The damper is located inside the taillight pocket, behind the hinge. The taillight needs to be removed to gain access to it.
I would say that all parts should be covered by the 3/36 warranty.
Bushing looks damaged so let's hope it's that. Either way I scheduled a visit to the dealer.
Yikes, is that a dent just to the left and up of the bushing? They might balk on the warranty and say it was abuse. You might have damaged the rod that runs the length of the tailgate, number 14 in the schematic. Good luck.
Hi Bushleaguechew,
We’re sorry to hear your tailgate isn’t cooperating. If you’d like, we’d be more than happy to touch base with your servicing GM dealership in regards to this concern. If this is something we can do for you, please let us know via private message. Thank you for being a valued customer, we greatly appreciate it!
Anthony
GM Customer Care
it's not dented
I just made this thread, just needed to search the keyword "tailgate"
http://www.gm-trucks.com/forums/topic/203858-tailgate-not-slow-opening-anymore/?hl=tailgate
You may not want to tell someone to order parts from the previous generation truck
correct part number is gm 84131760
Edited by truckguy82
You may want to get your facts straight before shooting off from your keyboard. My numbers came from a reliable GM site. Also, the previous gen did not use these parts since they didn't have a easy lower gate.
GM susperceded numbers all of the time. This is the case here.
Edited by 2017SierraSLT
Well don't know where you got it from, but the part GM 25815554 you listed does not exist on a 2014-2017 1/2 ton tailgate
Here's the part he needs, the bushing on our tailgates
Here's the one you told him to get, this part number is infact for a '07-'13 tailgate
I wouldn't mind so much if you weren't so confident in your advice. You were 100% sure, and this guy would have wasted money if he listened to you.
I am confident, so get over it.
As it turns out, We are both incorrect. I looked on another site, and the 25815554 is most certainly used on the 2014-up trucks, but for only those without the gate assist. I.E. W/T and cheap trucks.
Dealer is replacing the bushing and the damper sometime next week. Waiting on the parts to come in.
make sure to ask them for the part #s, so we can settle this debate once and for all. LOL
Oh its definitely the one I posted, I just went through this
I replaced mine about 18 months into ownership. Mine broke last week again. I'll check the part # and what I paid last time, but IIRC it was like $25 for the part online. If it's more than $10 it's not getting replaced again. Not playing this $25 bushing every 18 months game. Nothing wrong my arms, i'll lower the gate.
Part # 22966936 $26.80 is what I paid on 8/13/2016.
Edited by FL335i
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
