I recently installed these Rigid Back Up Lights in the bumper step. Very clean look. Light output is awesome from these very small lights. The install was fairly easy. I made a template using the light itself and taped it to the plastic to locate my holes for drilling. You need to position the light a little more on the outboard side of the step or the back of the light housing and / or wire will contact the truck body. Probably the hardest part was installing the top nut on the backside. After numerous tries, I was able to get it started holding it from the top with a long set of angled pliers placed through the opening between the bumper and body. Positive wires are connected to each factory backup light via a T-Tap, wrapped in electrical tape and the wire is protected in split loom. For the ground wire, I crimped on a ring and attached it to the bumper. There is a small screw conveniently located on each bottom corner.  I am very satisfied with these lights. You barely notice they are in there...
No, it does not was out the camera...the lights are actually angled down slightly as the back of the plastic step angles down a little. I don't know if this aids in not washing out the camera.
Rigid Insight Back Up Light Kit 20641
If you Google this, multiple vendors sell these for about $125.00. I purchased mine through AutoAnything.com...the were 25% off at the time...
On 11/13/2017 at 9:40 PM, winston04 said:
$99.00  @ www.northridge4x4.com/
thanks for that link... just placed the order lol
That looks great, but for me, I'm in and out of my bed like 50 times a day. I'd be scared to mess up some nice Ridgid lights. Those shots of the output from the inside are sweet, nice illumination.
Those really are nice.  They really work and seem to be out of the way, I have a cap so I never use these for steps.  These with my side mirror lights would turn night to day.  Good functional improvement.
  • 2 years later...
I crimped on a small ring to the ground wire and attached it to a screw on the bottom outside edge of the bumper...
Do you have any pictures from the back showing both sides, off during the day? Just curious how they blend in.
Here are a couple pics. You can see the small lense of the light, but the black housing blends in pretty well to the plastic housing...especially the further away you are...
I am looking at installing these.
how much of an angle does the light throw? Im mostly hooked up to my enclosed trailer but would like something to light up along the side of the trailer when trying to thread the needle in between other trailers In crowded hotel lots during snowmobile season.
thanks
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
    • Just saw on Jay Leno the new Scout. That’s the way it should be done.
    • EV's have their nuances too. Best to operate the current type of lithium batteries between 20-80% charge. No real need to charge until you hit around 20%. Occasionally charge to 100% when needed. Longer term storage, battery should be 50-60%. At least those are the guidelines for our iX. We've been exceptionally good to the battery in that car...easy to do when you can charge at home like we can.   EV's lack so many of the rituals and so much of the visceral feeling ICE vehicles provide, which is why I think they're hard to accept for a lot of gearheads. They're fun in different ways, though.
    • We have got a lot of rain lately, we needed it. Storms/lightning took out a floor fan. Dirt roads badly rutted from run off.   Power here is sketchy, whole house surge protector in the service panel and all electronics plugged into surge protectors. My biggest concern is my stereo, I've been an audio nut for years. $25 k in equipment. Stereo is on it's own special surge protector.
    • Happy Birthday!  I also turned 72 this year.  In some groups I consider myself to be a young senior and in others I realize I have serious years behind me!  In June I spent a week in the hospital due to a blood clot following knee replacement surgery.  The hospital Doctor assigned to my care specialized in Geriatric medicine!  He is a great Doctor but the fact I required this type of specialized care  made me feel old!  Aging comes with new challenges but I sure appreciate getting older!  It most definitely beats the alternative!!
