I just purchased a 2018 Silverado crew cab z71 with the 5.3 about a month ago and I have put about 1500 miles on it. This weekend I noticed when I was driving to and home from the desert that my temp would go a little over 210 while on a hill, and as soon as I would get to a less aggressive grade the temp would drop back down to 210 within seconds. The highest it has gotten was about 220, and I'm just wondering if this really is normal. I had a 2002 Silverado and it never went past 210, even when it was over 100 degrees out.
Welcome to having a real coolant temp gauge. Perfectly normal.
Sent from my SM-N910V using Tapatalk
Factory thermostat trigger temperature is 207 F with a +/-3 error. Don't kid yourself the oil temp is a good deal hotter. :lol:
Im a little surprised it would move at all. I have never seen mine moved even towing. I have a 1500 and a 2500 never seen the temp budge even hills or flat. Not sure what to tell you.
My 2017 6.2 Max tow runs hotter towing then did my 2015 5.3 by a noticble margin but not alarming as it cools when the fans kick in.
On my Sierra my oil temps are generally the same or lower then the engine coolant temps. I have a ScanGauge II monitoring engine oil temps. Normal highway driving (no towing) I see around 200F during the summer (190's winter). Towing 3000 lb boat in 5th gear I might see 215F. Everywhere I drive is generally flat so towing up grades would probably be a little higher. I believe all the EcoTec3 V8 engines have oil coolers (not sure about the V6).
I never notice mine moving even when towing up hills in the summer with the a/c on. Trans temp is another story however.
Oil coolers are standard with both the basic and max tow packages.
  • 4 years later...
It’s fine. My car’s normal ECT is 220-230*F. Boiling point is ~260*F on your engine. No worries.
There’s much less air on “the pass” than at sea level, which means less heat transfer.
Edited by 16LT4
1 hour ago, Brandon Ure said:
My 2016 Sierra was creeping up on 230 going over the pass. Came down as soon as the hill was breached, but makes me sweat a little. Any suggestions?
High heat makes a motor more thermally efficient but it doesn't make it more reliable. Heat is the enemy of reliability. For decades the design of cooling system utilized 180 F thermostats and radiators large enough to maintain that temperature. Then for some time it was 192 F and now..............
Question: What effect does heat have on oils viscosity? What effect does viscosity have on mechanical reliability? If you know the answers to those two the you have to ask yourself what it means for a motor whose specifications include both a 207 F thermostat AND 0W20 oils? 🤔
Normal? To the design it is. To longevity it isn't. You get to choose. How happy for you, right?
It may seem I didn't answer your question but within this reply is every piece if information you asked for and more.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
