Recommendations on Trim/Door Handle Removal in Houston, TX
On 1/29/2018 at 9:08 AM, Donstar said:
How did you do?  Last week I discovered an advantage to having this work done by a professional.  For some reason (probably this thread) I was checking out my mirrors.  I pushed on the cap and noticed there was some give on the driver's side but not the same on the passenger side.  I mentioned it while at my dealer last week and they will be replacing due to broken clips.  (no charge)  They didn't try to blame me and I didn't try to blame them!
Giving it a shot either tonight or tomorrow. I'll let you know! I decided to let the body shop handle my mirror caps as I was afraid of breaking a clip. They said they'd do them for free in lieu of having to put the front air dam skirt back on (since I'm going to trip it before putting it back anyway)
The place I used was BEYOND reasonable IMO. They charged me $100 to take my front grille and lower skid plate cover off AND put it back on. Well worth it IMO as they knew what they were doing and would be able to replace any broken clips, etc. that may occur during the removal.
  • 2 months later...
Where'd you get this done? I could do it myself for the most part, but I'm lazy :)
Place is called Victor's Body & Frame 1331 Upland Dr. Houston, TX 77043 they're just N of I-10 essentially on Wilcrest.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
